Go Back   Benzworld.org - Mercedes Benz Discussion Forum > General Mercedes-Benz Forums > General Mercedes-Benz
Old 07-20-2008, 06:04 PM   #1 (permalink)
Date registered: Jul 2008
Shut off valve/Solenoid help
I believe i need to replace my shut off valve. although i dont want to buy the part if i dont need to. am i able to tell if the one im using is broke or if i need to purchase a new one?
I had replaced my fuel filters and after when i went to fire up the car it only cranked. after doing extensive research and testing im assuming the shut off valve shut off the fuel line. Am i able to recock or not? i drive a 83 240d.
thanks, jeff
silverhalide1 is offline   Reply With Quote
A different strange noise - mono valve and vacuum solenoid block Y11 retiringinmind R129 SL Class 11 05-10-2008 08:29 AM
Leaky Variable Valve Timing Solenoid xerexabante R170 SLK Class 4 04-15-2008 08:05 AM
Replacing the diesel shutoff solenoid valve Cyberbach W123 E,CE,D,CD,TD,TE Class 3 02-05-2006 05:43 PM
NipponDenso Solenoid Valve orbits008 W211 E-Class 0 11-15-2005 12:27 AM
Solenoid valve??? Guest (MBNZ) W202 C-Class 2 12-13-2001 03:34 PM
