Am I entitled to a spare key? - Page 2 - Mercedes-Benz Forum
post #11 of 25 (permalink) Old 07-17-2008, 02:24 PM Thread Starter
Paul S320CDi's Avatar
Date registered: Jul 2008
Vehicle: S320CDi W220
Thank you all for you help.
I sometimes feel I am being petty about this but it's not like the old days where you could get one cut at the local shoe repair/key cutting kiosk is it.
Also being completely electronic if it fails I am going to be in trouble. I cannot rely on backup methods to start it (apart from the 2nd key).
I have spoken to him again today and something will be sorted out.
It makes you wonder how someone can loose a key the size of one of these.
I thought my old Range Rover keys were expensive at £115 each.
Paul S320CDi is offline
post #12 of 25 (permalink) Old 07-17-2008, 02:49 PM
MB-SV's Avatar
Date registered: Nov 2007
Quoted: 77 Post(s)
Great, glad it worked out well. You are "entitled" to whatever was negotiated and agreed upon, it's good thing you were firm about it.
S.
2013 Mercedes C250 Sport package PLUS steel gray metallic/black
2007 Lexus IS350 Sport package smoky granite mica/gray (+F-Sport, etc.)
2010 Honda Civic GX (CNG) white/tan
MB-SV is offline
post #13 of 25 (permalink) Old 07-17-2008, 03:08 PM
Jayhawk's Avatar
Date registered: Aug 2005
Vehicle: S500/W220/2000
Look at it this way: Unless you get the dealer to re-key/change the code on the key you get, there will be at least one and maybe two other keys out there that can unlock your car, start your car, and steal your car. That is no small matter IMO!
Don't believe everything you think
Jayhawk is offline
post #14 of 25 (permalink) Old 07-18-2008, 06:04 AM
Date registered: Dec 2002
Vehicle: 92 500SEL to 01 E320T current 2014 lexus LS460
The missing key can be "coded out" with the Mercedes software forever, a "replacement" key will wipe out the one it is replacing, or they can order a additional key and manually deactivate the missing one.
My dealer accidently ordered a wrong replacement for my defective remote, and it took out the good one, they had to reorder another. Typically cars with the smart key system came with two remotes and an emergency key which was a plastic fob about 1/8 inch thick with no remote functions but would start the car and had a metal key inside it similar to the remote. They keys can only be ordered thru a MB dealership!
Peter Guenther is offline
post #15 of 25 (permalink) Old 07-18-2008, 07:03 AM
Diesel Benz's Avatar
Quoted: 39 Post(s)
You must refer to older keys than those coming with current cars? For some time I have not seen a third key "emergency key". I can faintly remember a flat plastic key but is that from the time before EIS communicated with the key via IR? If I remember right, this flat key would not have IR and could not be used with current cars?
Diesel Benz is offline
post #16 of 25 (permalink) Old 07-18-2008, 10:12 AM
Jayhawk's Avatar
I got two e-keys and one flat plastic "valet key." When I bought my car new in 2000.
Jayhawk is offline
post #17 of 25 (permalink) Old 07-18-2008, 10:42 AM
Quoted: 39 Post(s)
But was that valet key an IR key? Which car was it? My W210 was from 2000 but I'm not sure any more if it did have more than the two basic keys (this car only worked with an IR key). My W211 and W221 definitely only came with two keys.
post #18 of 25 (permalink) Old 07-18-2008, 12:32 PM
Jayhawk's Avatar
I think it is an IR key because it has that red shiny plastic tip on it, plus it has a slide-out metal key; but it is only about 1/8" thick and I belive it will start the car and I have to use the metal key to lock/unlock doors etc. It is called an "electronic reserve key" in the Operator's Manual.
Jayhawk is offline
post #19 of 25 (permalink) Old 07-18-2008, 12:48 PM
Quoted: 39 Post(s)
In this case the key must be one that would be compatible with the W210 I had and even should work on the W211 or W221 (would start the car as it has the IR transceiver). I might have a look at the US W221 manual, never know if US cars have a different set of keys with them compared to our cars.
post #20 of 25 (permalink) Old 07-19-2008, 06:45 AM
NJRSLK280's Avatar
Vehicle: June08 SLK280 black fully loaded 06 focus ST 2.5T blue
Send a message via AIM to NJRSLK280 Send a message via MSN to NJRSLK280
Paul
good luck with you new merc, i too am in the uk, from posts on my RS owners club beware that there are some scams where the spare key is kept and then when you own the car someone comes and help themself to the car back, please make sure that the "lost key" is decoded and will not open the car, if me like with any lost keys i would be asking for a new set and new locks to be on safe side
hate to be bearer or bad new but this does happen so best to make you aware
good luck
Neil
NJRSLK280 is offline
spare key nkpnkp W124 E,CE,D,TD Class 9 04-13-2010 08:57 PM
3 button key spare key $480!!?? Benzguy888 W211 E-Class 18 09-03-2007 05:01 AM
Spare key question StevE320 W211 E-Class 2 06-07-2007 10:14 AM
Spare Key amokwa W210 E-Class 1 02-15-2004 06:44 PM
spare key/ vallet key blue420sel W126 S,SE,SEC,SEL,SD,SDL Class 2 01-31-2004 05:29 AM
