» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > General Mercedes-Benz Forums > General Mercedes-Benz
Old 07-16-2008, 04:09 AM   #1 (permalink)
Date registered: Jul 2008
Vehicle: 2003 C230 Kompressor Coupe
Send a message via Yahoo to Zgorzi
Unhappy Cylinder #2 valves burnt - Is this normal??
I am new to this forum and hope to get some insight and advice from other MB owners. I am devastated. My Benz, not even 6 years with 75,000 miles came on with a check engine light and a code saying "cylinder #2 misfire. It still runs fine just when I am at a stop sign or traffic light it sometimes idles rough. I brought it to the dealership and they told me that the valves in #2 are burnt. Cost for fixing around $3,500. Is that usual for a car, especially a MB, at 75,000 miles??? I never had problems before and after researching on this I found a lot of stuff and know I am wondering: If I get #2 fixed, is #1, 3, or 4 going soon to be burnt too? I checked with my dealership and they are willing to go down to $2,500 based on good will, but if I have possibly 3 more cylinders to get fixed....does anyone here has experienced something similar or can give me advise on this?
Zgorzi
Zgorzi is offline   Reply With Quote
Old 07-16-2008, 04:46 AM   #2 (permalink)
Vehicle: W211 E320CDI & V221 S320CDI
I would suggest you to ask what is covered by the $2500. I would assume they change all valves and prepare the head appropriately, the cost is mostly labour anyway. If you then run with good fuel and keep the engine serviced, you should not get another valve issue any time soon.
Diesel Benz is offline   Reply With Quote
Old 07-16-2008, 05:11 AM   #3 (permalink)
The dealer would fix the valves in Cylinder # 2 and prepare the head for the $2,500 + tax. I always bought premium fuel, never ever anything below 91 -93 and had it alwys serviced at the dealer for A and b service and it still happened though.
Zgorzi
Old 07-16-2008, 07:08 AM   #4 (permalink)
OK. Which model is it? Have you tried searching the sub-forum for this MB model, perhaps it is a known issue and perhaps there are owners who have experience about the same issue? Would not harm posting the question at the appropriate other sub-forum.
Old 07-16-2008, 05:46 PM   #5 (permalink)
Musikmann's Avatar
OK it is a W203 so look for that sub-forum and start another thread there. If it is a known issue, there should be several others in the same boat.
Exhaust valves burnt miked56 R/C107 SL/SLC Class 4 12-18-2007 06:39 AM
4th cylinder knock and blow by. Valves, sleeves, or rings? greenguru W126 S,SE,SEC,SEL,SD,SDL Class 0 06-23-2007 10:09 AM
3 Valves per Cylinder. How does it work? lnguyenh General Mercedes-Benz 11 07-17-2006 05:35 AM
Burnt valves on C230K Guest (MBNZ) W202 C-Class 3 08-06-2002 06:06 AM
Why do most Mercedes have 3 valves per cylinder? Guest (MBNZ) General Mercedes-Benz 4 05-12-2002 07:09 PM
