tire pressure - Page 2 - Mercedes-Benz Forum
post #11 of 20 (permalink) Old 07-15-2008, 06:05 PM
MB-SV's Avatar
Date registered: Nov 2007
Quoted: 77 Post(s)
Originally Posted by Musikmann View Post
I just bought a set of BF Goodrich Traction T/A last week from my dealer. The tech pumped 35psi into them (I didn't know until I checked pressures today) and the door pillar says 27psi for normal load and speeds. I called the parts guy who recommended these tires and I asked if all techs did this and he said yes and it's because we get better wear from them. I think I'm going to lower them somewhat because they are a bit stiff, but I have never run with the 27 thinking it is too low.
Wow, a MB tech should know better. Yes you might get better wear, but very likely to wear early in center of tire.
Best to dial in the pressure first thing in the morning (cold) before driving, given door pillar label and your preference of course.
S.
2013 Mercedes C250 Sport package PLUS steel gray metallic/black
2007 Lexus IS350 Sport package smoky granite mica/gray (+F-Sport, etc.)
2010 Honda Civic GX (CNG) white/tan
MB-SV is offline
post #12 of 20 (permalink) Old 07-15-2008, 06:27 PM
Musikmann's Avatar
Quoted: 6 Post(s)
Hey MB-SV,
That's what I thought too but please allow me to add this. The CPO car with 53,000 miles had a new set of Continental ContiProContacts mounted when I bought it almost exactly 24 months ago. I now have a little over 71,000 and the damn things were shot. I mildly complained to the parts guy (after 3 different techs told me the tires were badly worn) and these were what he recommended, at least partly because they would last longer. He also said he "got a good deal on them". They do have the 93H MB recommended load/speed.
I thought the Contis were excellent handling tires, but 18.000 miles? Sheesh, that's ridiculous! Not to mention that they charge $130 for the OEM Contis and these were $112 each.
Musikmann is offline
post #13 of 20 (permalink) Old 07-15-2008, 06:43 PM
MB-SV's Avatar
Quoted: 77 Post(s)
MM - Good info. I too had mediocre tread life with Contis on a 01 MB C240 and 05 Jag X-type in the past.
I'll monitor the OEM Michelin 17" staggered tires on the 08 C300 Sport (has about 12K miles so far) and let you know if they should be recommended. So far, so good.
S.
MB-SV is offline
post #14 of 20 (permalink) Old 07-15-2008, 06:50 PM
Musikmann's Avatar
Quoted: 6 Post(s)
Thank you in advance MB-SV. I thought about Michelins, and being the way I am, would have preferred to stick with OEM tires. I'm not sure, but the new E-Class come with either Michelins or Contis. As an afterthought, I should have called MBUSA to see what tires were OEM for my car and bought whatever else they used other than Continentals. BTW, the spare is a Conti so I assume (bad idea I know) that those were the original tires.
post #15 of 20 (permalink) Old 07-15-2008, 09:26 PM
Kajtek1's Avatar
Quoted: 1223 Post(s)
I've been dong 60,000 on Michelins. I also made over 60k on General's on our ML320, but had to replace 2 of them earlier because of flat. If you like hard cornering, you better add couple of psi. I drive on min 30 psi in the rear and above 30 in front and still have sides wearing more than center.
Coming back to original question. Changing the tire profile generally should not change the tire inflation. If in doubt, you should contact tire manufacturer for advise. Usually they have pressure recommendation varied with the load, so you need to find the load on your tires.
Kajtek1 is offline
post #16 of 20 (permalink) Old 07-16-2008, 01:18 PM
Mercedes Benz of Florida's Avatar
Date registered: Dec 2006
Vehicle: 2000 Mercedes-Benz S500. Sold: 2000 C230K, Sold: 1997 Porsche 944S
Quoted: 26 Post(s)
Send a message via Yahoo to Mercedes Benz of Florida
Originally Posted by 00_230_K View Post
thanks i know the factory psi specs but thats for 195/65/15 tire this is a 225/40/18 and for the gas i know its a 91 minimun but i was asking for shell if if its better than others, thanks again
A note of CAUTION here.
You are running 225's in a car rated for 195 or 205.
Do not be surprised if your Alignment is off.
Do not be surprised if your tires prematurely wear faster than
tire mfgr. rated them for.
From 15 inch to 18"? Wow.
Your alignment symmetry is way off.
I hope you have your car realigned.
Also your Speedometer, with the severe out of specs; is no longer accurate.
Just food for thought....
Charles
New York City, NY
Richmond County
United States of America
Mercedes Benz of Florida is offline
post #17 of 20 (permalink) Old 07-16-2008, 04:40 PM
MB-SV's Avatar
Quoted: 77 Post(s)
An extra 1.6 inches taller in diameter, great if you are trying to get more ground clearance for offroading.
S.
MB-SV is offline
post #18 of 20 (permalink) Old 07-16-2008, 05:42 PM Thread Starter
00_230_K's Avatar
Date registered: Jul 2008
Vehicle: 2000 c230 kompressor
more ground clearance for sure , way better handling and stability with 225/40, looks alot better but
burns more gas too
00_230_K is offline
post #19 of 20 (permalink) Old 07-17-2008, 07:24 AM
MB-SV's Avatar
Quoted: 77 Post(s)
burns more gas too
And significantly slower acceleration, not a good setup at all.
S.
MB-SV is offline
post #20 of 20 (permalink) Old 07-17-2008, 02:00 PM Thread Starter
00_230_K's Avatar
im not after acceleration or speed im more into the styling of the car and the looks i love a clean looking benz check 'er out
Name:	SL380171 (816 x 612).jpg
00 C230 Kompressor
Hamilton, Canada
00_230_K is offline
    Tire Pressure rshahz W221 S-Class 3 11-15-2007 10:28 AM
    taking down tire pressure for 4x4 ing. could you do that on a low profile tire? blau The Discount Tire Direct Tire, Wheel, Brake & Suspension 1 01-06-2006 01:49 PM
    tire pressure mr diesel W123 E,CE,D,CD,TD,TE Class 1 06-20-2005 05:06 PM
    tire pressure jimand7 W211 E55 AMG, E63 AMG 6 12-02-2004 09:56 PM
    Tire Pressure s0vietbenz W140 S-Class 6 01-15-2004 06:08 AM
