w124 idle - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 07-14-2008, 04:05 AM Thread Starter
Date registered: Jul 2008
w124 idle
Hi, my 230te idles fine at startup and all the way up to approx 80 degrees when it then launches idle into space at around 1400 revs. Have fiited new airtemp sensor as that was obviously a broken loop. Any ideas?
230teehee is offline
post #2 of 2 (permalink) Old 07-14-2008, 06:41 AM
Yal
Date registered: Sep 2004
Coolant temp sensor. Green one on top of the engine near the front.
Also remove the air cleaner and remove the idle control valve. Clean it or soak it in some parts cleaner and then put it back. Inspect the hoses.
Yal is offline
    W124 E300D Engine Idle Speed Low p_aplin W124 E,CE,D,TD Class 0 06-06-2008 06:04 AM
    w124 230ce idle surge then stall voda W124 E,CE,D,TD Class 7 12-25-2007 05:00 AM
    could faulty/dirty idle control valve (IVC) cause all these problems on w124? wawago W124 E,CE,D,TD Class 10 07-19-2007 11:01 PM
    W124 E 250 Diesel -idle speed adjustment JDA W124 E,CE,D,TD Class 0 05-30-2006 03:21 PM
    W124, idle/acceleration issue, oil on 2 plugs, CorvairTurbo W124 E,CE,D,TD Class 2 01-17-2006 04:32 PM
