87 420 fuel dist - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 07-13-2008, 08:39 PM Thread Starter
Date registered: Jul 2008
87 420 fuel dist
Hello Guys,
How you can help with this problem.
I mostly work on VW/AudI,BMW,PORSCHE I Have little experience with MB..And with that lack of info for resolving this problem is slim to non..Vehicle was brought to me on a wrecker.I discover all cyl are flooded, plugs are fowled,oil is contaminated with fuel.customer told me he pulled over to change tire vehicle wouldnt start after that.i checked return line,checked out fine,found ripped diapham on fuel dist reg replaced hoping it would fix problem no luck..check 9th injector operating fine,throttle plate nice and smooth and nice tension.after cranking for several times engine hydro locks with fuel.
Fuel pressures are 7 bars at pump
3.1 bars when cycling the key with fuel gauge between dist@reg"open loop" but drops to 0 when you let off the key.
3.2 bars during cranking
1-2 bars at test plug on right side of fuel dist
i can make vehicle run "but runs highly rich" by disconnecting fuel line from fuel dist to pressure reg and running line to fuel can..eliminating back pressure in fuel system.Im thinking fuel distributor but do to the cost i want to make darn sure its the problem before replacing it... so any help would be great thanks
lrover76 is offline
    HAH! I have the problem nailed (fuel dist?) Darkwind W124 E,CE,D,TD Class 6 03-31-2008 09:01 PM
    91 500sl air dist hoses jnorth R129 SL-Class 4 04-09-2007 06:22 AM
    cant find my plugs and dist cap!!! Carlo$ R129 SL-Class 4 04-03-2007 05:45 AM
    Dist. cap question lander91 W126 S,SE,SEC,SEL,SD,SDL Class 5 01-19-2006 02:58 PM
    Fuel '86 420 SE mercedes_4_ladies W126 S,SE,SEC,SEL,SD,SDL Class 3 03-05-2004 06:06 PM
