» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > General Mercedes-Benz Forums > General Mercedes-Benz
Old 07-04-2008, 08:38 PM   #1 (permalink)
JBeans's Avatar
Date registered: Jun 2005
Vehicle: 05 C230 Sport Sedan
4matic or not
I am thinking of getting a C300/C350 4matic because I find my car not as sure-footed as I like it to be in our great Canadian winter. There are quite a few scary moments as my car does not go in the direction that I steer.
Do you think that a 4matic can prevent me from fishtailing in snowy condition? Does the car sacrifice some of its power/acceleration due to it being 4matic?
Your opinion is much appreciated.
Curiosity killed the cat. Come on, kitty kitty. What's in the water?
JBeans is offline   Reply With Quote
Old 07-04-2008, 08:42 PM   #2 (permalink)
Mike Tee's Avatar
Date registered: Aug 2007
Vehicle: see signature
Send a message via Yahoo to Mike Tee
They cost more, cost more to repair, weigh more and drink more fuel. I would stick with the 4 cylinder model you have now and maybe get some better winter tires for it. Can you imagine paying $2.50 per L in a couple of years, for a car that drinks 14 L/100 km?
2008 Mercedes-Benz B 200
2005 smart fortwo cdi pulse cabriolet, loaded
1966 Peugeot 404 Coupé Injection
1989 Peugeot 405 DL, 366,000 km
Mike Tee is online now   Reply With Quote
Old 07-04-2008, 08:54 PM   #3 (permalink)
Date registered: Sep 2005
Vehicle: 2002 ML320 - Capri Blue!!
Unless you have another car that does much better in the winter than the C that you could use, I'd go with the 4Matic.
asianml is offline   Reply With Quote
Old 07-04-2008, 11:19 PM   #4 (permalink)
Vehicle: W211 E320CDI & V221 S320CDI
I agree with both comments above (mostly, even if they are perhaps opposite to each other). But you should not expect 4-matic reducing fishtailing a lot, it is more for increasing grip when you have trouble getting forward at lowish speed. ESP would make a RWD car equally stable (give or take a few very exceptional cases where the difference in stability would still be small).
A 4-matic too should be driven with good winter tyres if you have a real winter with (occasional) snow.
Diesel Benz is online now   Reply With Quote
Old 07-05-2008, 07:14 AM   #5 (permalink)
Date registered: Dec 2007
Vehicle: 2000 E430 4Matic
Let's get one thing clear: 4Matic (or any all-wheel-drive system) DOES NOT improve traction for steering. If your car isn't going where you steer it, that's because the FRONT tires are losing traction. 4Matic only improves traction for accelerating, not turning.
Fishtailing is the result of the REAR tires losing traction. 4Matic should reduce fishtailing because the front wheels are also pulling. HOWEVER, note that MB biases the amount of power to the rear axle so it drives MORE like a RWD vehicle, so with the traction control turned off, it is possible to make a 4Matic fishtail. I've done it on my E430 4Matic.
Finally, YES, 4Matic causes a slight sacrifice in power and acceleration. First, there are more mechanical gears which causes a loss in power reaching the wheels due to mechanical friction. Second, the 4Matic system makes the vehicle heavier. More weight means slower acceleration and increased fuel consumption. Having said that, 99.9 percent of drivers will never perceive the difference in performance.
Cheers from Edmonton.
Tim
T-88 is offline   Reply With Quote
Old 07-05-2008, 02:18 PM   #6 (permalink)
MB-SV's Avatar
Date registered: Nov 2007
I agree.
S.
2006 ML350 white/ash
2008 C300 Sport mars red/black
2004 986S seal gray metallic/black/black
MB-SV is offline   Reply With Quote
Old 07-05-2008, 10:19 PM   #7 (permalink)
Kajtek1's Avatar
Vehicle: E300DT/320cdi ML320/55
I am in California and I drove 4-Matic wagon for few years -selling it only because they don't come with diesel.
The 1 mpg loss is nothing comparing to the confidence of taking sharp turn after the rain, or not having to put chains on, when I go skiing.
Actually one crossing of desert flood in Nevada made all the sense of owning 4-Matic I needed.
Kajtek1 is online now   Reply With Quote
Old 07-05-2008, 11:26 PM   #8 (permalink)
MB-SV's Avatar
MB's minimal gas mileage loss with 4wd makes it a non-issue. And those of us that live in California and drive into the Sierra mountains in the winter will appreciate 4wd frequently when they can legally avoid installing chains (chain requirements are enforced on the major highways in California).
Old 07-06-2008, 08:48 AM   #9 (permalink)
JBeans's Avatar
Thank you all for your opinions. I will consider a 4matic for my peace of mind.
Old 07-07-2008, 07:11 AM   #10 (permalink)
flyboyike's Avatar
Date registered: May 2003
Vehicle: '79 280E
If you want sure-footed, may I recommend a billy-goat or, failing that, a Denali snow sheep? Those fuckers don't fall, ever.
flyboyike is offline   Reply With Quote
4Matic Woes 2004 s500 4matic bigbodyw140 W220 S-Class 0 05-05-2008 01:56 PM
C240 4matic Or C320 4matic? mattflyae W203 C-Class 11 03-14-2007 08:08 PM
1992 300TE 4Matic Vs. 2000 E320 4Matic dogwagon General Mercedes-Benz 5 02-27-2007 09:31 PM
300TE 4Matic to non-4matic conversion hellspcangel911 W124 E,CE,D,TD Class 4 02-13-2006 08:18 AM
2001 E430 4matic or 2002 E320 4matic alexnatt W210 E-Class 15 12-14-2005 09:51 AM
