Go Back   Benzworld.org - Mercedes Benz Discussion Forum > General Mercedes-Benz Forums > General Mercedes-Benz
Old 07-03-2008, 09:57 AM   #1 (permalink)
Date registered: Jul 2008
How to re-install keyless go gear shift knob?
Me newbie just bought a 2005 CLK with Keyless Go, after having read lots of positive comments about this car. Since searching this and other Benz fora didn't help, here comes my story.
Help please!
The gear shift knob with the start/stop button had been removed from the car during shipping.
I figured out how to mechanically mount the knob, but the start/stop button now does not work at all.
I know it worked fine before the shipping! There must be something I am missing here. I can unlock the car in a keyless manner, the key also is detected inside the car, but the button is dead. No ignition, no keyless starting while braking. The engine can be started using the key, but this is not what I want.
Does anybody have a clue how to solve my problem? Your help would be greatly appreciated.
USCLK05 is offline   Reply With Quote
Old 07-04-2008, 06:42 AM   #2 (permalink)
Date registered: Jan 2007
Vehicle: 2002 honda civic
what does it say on the cluster when you try and start the car?
Streetglower is offline   Reply With Quote
Old 07-04-2008, 10:46 AM   #3 (permalink)
Thanks Streetglower for trying to help!
What it says? Nada. There is no reaction at all, as if the button hadn't been touched. Let me give you the following additional info:
When I have the key inside the car, let's say in my pocket, and slide the shift knob onto the lever:
- foot off the brake, the ignition comes on, the "P" for parking is lit, but after that the button does not have any further effect, no matter how often I press it.
- foot on the brake, the engine starts when I slide on the knob, but after that the button does not turn off the engine, it does not do anything anymore.
I tried the same with the key outside the car, I then got the info "key not found" in the display when sliding on the shift knob. Probably the main battery has been disconnected during shipping, with the shift knob removed. However, I have tried already to disconnect the battery, slide on the shift knob, re-connect the battery hoping for an initialization of some kind, but to no avail.
There must be some trick I am not aware of - kind of frustrating, but nothing more really. As much as I appreciate your help, please don't waste your precious time on this problem unless you can quickly find the solution, I wouldn't like to steal your quality time!
Old 07-12-2008, 12:32 AM   #4 (permalink)
Short update: Somewhere I read that for resetting the vehicle's electronic system one would have to disconnect the battery for a couple of minutes, not only seconds as I had done before.
So I disconnected the main battery of my W209 for 5 minutes, reconnected it hoping the keyless go start button would work - but the only change I achieved was that the keyless entry stopped working as well (in some thread related to this new problem it is said that using the key for some time in the ignition re-enabled keyless entry - will see).
Is there anybody out there who has insight into the functioning of the keyless systems? Do these units really fail so often as it appears, or are they just used by MB dealers to make a quick buck because hardly anyone understands how the different components work and a 'repair' is easy money?
Old 07-12-2008, 02:16 AM   #5 (permalink)
Vehicle: W211 E320CDI & V221 S320CDI
You mean do the shift knobs get removed often during shipping? I'm interpreting this being your only issue. If you reinstalled an new shift knob, I'm guessing your wiring was affected when the knob was removed and you would have to fix that. Have you measured if the wiring is OK?
Your user manual would probably tell how to make your KG system operational again after power loss.
Diesel Benz is online now   Reply With Quote
Old 07-12-2008, 03:49 AM   #6 (permalink)
Wiring, hm. I frankly do not think there is any wiring needed. At least, I haven't seen any wires - and the vehicle reacts nevertheless in the funny way described above. Also the manual doesn't give any information specific to the keyless go. As if there were no problems to be expected.
Old 07-12-2008, 12:14 PM   #7 (permalink)
Don't you have the start/stop button at the gear stick? I was referring to the wiring for this button. The fact that your car stopped detecting your KG key is a different thing (I don't have KG myself, cannot comment if it needs any initialisation after power loss).
Old 07-13-2008, 09:19 AM   #8 (permalink)
There are two little pins inside the shift knob and corresponding holes in the lever into which the pins will be inserted when sliding on the knob. Everything looks as if it should work, I don't think there is a mechanical problem - when sliding the knob onto the lever, a signal is created as if the button had been pressed. This works only once and after that the button remains dead and useless.
Old 08-02-2008, 12:39 PM   #9 (permalink)
The solution, at last:
1. The start/stop button of the keyless go system did not work. SDS stated "switch is stuck" or something like that. Dealer said he would have to order a new shift knob.
Knowing the problem was in the shift knob, I went home and disassembled the knob to get to the contacts of the start/stop button. The two contacts wires were twisted around each other, which one could not without taking the shift knob apart, and produced a short circuit. I do not have any idea how this happened. After removing the short circuit the start/stop button works flawlessly again. So, apparently no special procedure has to be followed when re-attaching a keyless go shift knob to the car again.
2. Keyless entry worked again after the keys had been assigned to the locking system of the car again with the SDS (keyless entry had stopped working after disconnecting the main battery for 30 minutes).
Thanks for helping!
Gear shift knob for the 32 16falcon R170 SLK Class 3 01-10-2006 05:24 PM
Loose gear shift knob Gregs300CD W123 E,CE,D,CD,TD,TE Class 4 08-01-2005 02:35 PM
Gear Shift Knob Help!! JOESID W202 C-Class 0 07-14-2005 07:37 PM
Birdseye Maple Shift Knob for Keyless GO luvspipes W211 E-Class 1 12-21-2003 07:15 PM
How to remove gear shift knob? ml W163 M-Class 2 01-08-2002 03:49 PM
