Proper A/C R-134a Pressure Value? - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 07-03-2008, 06:31 AM Thread Starter
Date registered: Mar 2007
I have searched on this but couldn't find a definitive answer. While doing my A/C Diagnostics I found that my Sensor 7 reading is only "07". I have bought a recharge kit but I wanted to know what an acceptable value for this sensor is. I have seen some people posting a value of "17". I don't want to overcharge the system.
Thanks,
-Frank
FrankiE55 is offline
post #2 of 5 (permalink) Old 07-06-2008, 07:02 AM Thread Starter
anyone?
post #3 of 5 (permalink) Old 07-07-2008, 05:10 AM Thread Starter
post #4 of 5 (permalink) Old 07-08-2008, 02:46 AM
Date registered: Jan 2007
Vehicle: 2002 honda civic (sold), 2009 Mercedes ML350
Quoted: 4 Post(s)
you cant base what the system is doing by that number. a system that is properly charged by is not working is going to have a low value for pressure. that is cause the compressor is not building any pressure and the system is idle. once the compressor kicks in, the pressure will start to build. usually between 11-17 bar. to accurately diagnosis, you need to hook up gauges and see what the system is doing. you could be low or have a faulty component.
Streetglower is offline
post #5 of 5 (permalink) Old 07-08-2008, 08:52 AM
Kajtek1's Avatar
Quoted: 1289 Post(s)
You can buy a pressure gauge at automotive story, that has refrigerant level already marked on it. Since the system has accumulator, it will work in pretty wide range of pressure, but main point is, that low side should not drop below 30 psi. E class has the pressure display on climate console. I keep my systems at about 5-8 bars static pressure, what gives it 16-22 pressure under heavy load. Once the interior cools down, usually working pressure is about 14 bars
Kajtek1 is offline
Proper fuel pressure... Bob 1000 W163 M-Class 21 06-25-2010 07:40 PM
2001 E320 4Matic: Proper tire pressure Tidalcloud W210 E-Class 13 07-22-2008 11:41 AM
Help With Proper Tire Air Pressure smarten W164 M-Class 15 11-25-2007 11:10 AM
Proper inflation pressure for winter tires? BB54K R171 SLK-Class 9 12-07-2006 07:02 AM
Proper Tire Pressure bartlettplace R230 SL-Class 14 08-27-2005 09:47 AM
