license plate --- seized screws - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 07-02-2008, 01:54 PM Thread Starter
Date registered: May 2008
... and now for the silliest question ever !!!!
I just bought a c230 - 2005 coupe ... and i cannot mount the new license plate ... the screws ( one is broken one is missing ) the other two seem to be seized and the complete base is rotating .. tried w40, holding base with vise grips etc
any thoughts ?
onyxrain is offline
post #2 of 4 (permalink) Old 07-02-2008, 05:24 PM
Date registered: May 2004
Vehicle: Debadged 6-Speed '05 C320 Sports Coupe
Drill 'em out and re-tap. I did it to mine and they're fine now.
wingless is offline
post #3 of 4 (permalink) Old 07-07-2008, 04:19 PM
Date registered: Feb 2006
Vehicle: 2001-W210-CAPRI METALIC BLUE-/ 2002-W210 E300D
Location: Los Angeles, Ca, Aberdeen Scotland, Lawrence Ks.
Quoted: 2 Post(s)
Cool Hey on..
when you replace them be sure and use STAINLESS STEEL screws. It IS a Mercedes after all...
The finest example of automobile engineering in the world
Floats like a CADI
Stings like a BMR
Stingy as a Prius
and.... all Mercedes Benz.
MRBSMITH is offline
post #4 of 4 (permalink) Old 07-08-2008, 02:47 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
...and be sure to use the correct METRIC screws. One of mine was badly damaged because some numbskull crammed an SAE machine screw into it. When I pull the liner to replace the license plate lights I plan on seeing if I can re-swage/seat the "nut" as mine spins pretty easily. (I was able to get hold of it with needlenoze vice-grips and remove the offending fastener and ran the proper one through it a couple of times, which was sufficient to restore the threads.)
Take care and enjoy the ride,
Check Codes is offline
    Can't remove rear license plate screws! E430_4Matic W210 E-Class 7 06-27-2007 12:14 PM
    License plate screws too long chastylr X164 GL-Class 8 05-31-2007 08:14 PM
    license plate mouting screws & inserts bass1175 W140 S-Class 10 04-15-2007 04:28 AM
    License plate screws on 82 300D kaminskc W123 E,CE,D,CD,TD,TE Class 1 12-10-2006 06:02 AM
    License Plate Screws k6lw R170 SLK-Class 5 01-01-2003 03:04 PM
