PDF - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 06-29-2008, 01:45 PM Thread Starter
Date registered: May 2008
Vehicle: 97 S500 Coupe
PDF
is there anything special i have to do to open the pdf's? they will not open for me.
cheebs is offline
post #2 of 11 (permalink) Old 06-29-2008, 02:00 PM
twalton's Avatar
Date registered: Jan 2005
Vehicle: 2008 S550 designo
Adobe Acrobat Reader - free download.
tw
twalton is offline
post #3 of 11 (permalink) Old 06-29-2008, 02:02 PM Thread Starter
tw
i had adobe 6 it didn't work updated to 7 it didn't work
cheebs is offline
post #4 of 11 (permalink) Old 06-29-2008, 05:53 PM
ohlord's Avatar
Vehicle: 1994 E320 Wagon,1999 E320 Wagon,2000 E 320 Wagon, MGB Track/Rally, ,1988 300E ,more....
Quoted: 5 Post(s)
Run
it in firefox.
ohlord
remove the old adobe reader first and do a clean install.
ohlord is offline
post #5 of 11 (permalink) Old 06-29-2008, 09:59 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Cheebs, generally there is no reason to uninstall previous adobe versions and the app is pervasive enough that you would pretty much have to format your hard drive and start from scratch if you truly wanted to uninstall it.
I would guess that the problem you are having is more likely related to your connection, PC resources or a plug-in issue. In any event just right-click on the pdf you're looking at and choose "save target" or "save as" and then once it is downloaded you can just double-click it to open it. That will almost always work.
Take care and enjoy the ride,
Greg
Check Codes is offline
post #6 of 11 (permalink) Old 06-29-2008, 11:08 PM
raymond-'s Avatar
Date registered: Jan 2004
Vehicle: 99 E320
Quoted: 138 Post(s)
what is the resulting message shown, or dialog box you see, when you attempt
to open the file. how are you attempting to open the file?
W.A.G.....
go into File Manager
right click the desired PDF file and select CHOOSE PROGRAM
select Adobe Reader....and....be sure that you click
- "Always use the selected program"
and see if this resolves the problem
raymond-
47º34'N 122º18'W
raymond- is offline
post #7 of 11 (permalink) Old 06-30-2008, 07:13 AM
MY2008ML350's Avatar
Date registered: Mar 2008
sometimes it's also caused by the pdf file itself, there maybe some corruption in the file or it was not saved properly. Try opening other pdf files, if you can, then the problem is this particular file..
2010 B200, Polar Silver, Premium Pkg
2008 ML350, Obsidian Black, Premium Pkg
2008 C300, Calcite White
2007 C230, 040 Black, Premium Pkg (gone)
MY2008ML350 is offline
post #8 of 11 (permalink) Old 06-30-2008, 08:34 AM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 712 Post(s)
Use Firefox browser. My guess is that you're having a problem with IE.
GeeS is offline
post #9 of 11 (permalink) Old 06-30-2008, 09:13 AM
Jayhawk's Avatar
Date registered: Aug 2005
Vehicle: S500/W220/2000
I've opened hundereds of PDFs in IE w/out ever having a single problem... Not sure what you're talking about...
Don't believe everything you think
Jayhawk is offline
post #10 of 11 (permalink) Old 06-30-2008, 09:19 AM
Quoted: 35 Post(s)
I work in IT. 99 times out of a hundred in this situation the problem is the Acrobat plug-in to the browser, whether that is IE, Mozilla, Netscape, Opera, etc. Sometimes it's corrupted by a subsequent patch (either to the browser or the app) or a conflicting app (goofball downloads that conflict with file settings or the plug-in itself) or it can also be a new digital camera or scanner that was installed with a version of Adobe photoshop "lite", elements, etc. that messes up the plug-in or a shared dll, etc.
You can easily spend hours trying to figure it out or you can simply download and open the pdf files. If you don't want to keep them it's easy enough to delete them afterwards. Plus you don't have to then be on line to view them later.
    PDF Test 2 RichardM98 Test 2 11-28-2007 01:21 PM
    PDF Test RichardM98 Test 0 11-28-2007 10:05 AM
    Manual on PDF? tempoct R170 SLK-Class 10 09-05-2007 03:57 AM
    Need to post PDF Ratso W163 M-Class 16 10-22-2003 09:18 AM
