The Gas-Diesel engine(DiesOtto) - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 06-21-2008, 04:06 AM Thread Starter
MY2008ML350's Avatar
Date registered: Mar 2008
Post Is gas-diesel engine best of both worlds?
Mercedes gives a glimpse of the future with prototype of new kind of powerplant
The DiesOtto acts like both a gas and a diesel engine: under hard throttle, it acts like it’s gas powered; when it isn’t being pushed hard, it acts like a diesel.
For additional details:
2010 B200, Polar Silver, Premium Pkg
2008 ML350, Obsidian Black, Premium Pkg
2008 C300, Calcite White
2007 C230, 040 Black, Premium Pkg (gone)
MY2008ML350 is offline
post #2 of 2 (permalink) Old 06-21-2008, 04:11 AM Thread Starter
Post The Gas-Diesel engine(DiesOtto)
From MBz:
In theory, a Homogeneous Charge Compression Ignition engine like the DiesOtto removes the contrasting combustion cycle weaknesses in both gas and diesel engines.
In a gas engine, fuel and air are mixed into a chamber, then compressed by a rising cylinder head. A spark from the spark plug then ignites the mixture, and – boom! – the explosion pushes back down the cylinder head, which then rotates a crank that eventually turns the wheels on your car.
The trouble with gas engines is when you're not on full throttle, which is most of the time, they aren't very efficient.
During this "part-load" operation, a gas engine's throttle valve on the intake partially closes to limit the amount of air entering the cylinder. This sucks additional power from the engine to overcome the partially open valve.
In a diesel, there is no throttle. Air is compressed in the cylinder until the temperature is high enough to cause ignition without a spark (that's where the term "high-compression" comes from; typically twice as much as a gas engine.) The amount of diesel fuel required is determined by ignition, not by the timing of the spark plug.
In contrast, an HCCI engine, powered by gasoline, employs automatic-ignition (diesel) under part throttle, and spark-ignition (gas) when accelerating or during cold starts. Its combustible air and fuel mix is compressed in the cylinder, heating up to the point where it begins to burn.
In a gas engine, this is inefficient, as a spark should control combustion. But in an HCCI mill, combustion throughout the chamber – instead of just at the spark plug – keeps temperatures low. And low temperatures means fewer emissions, says Mercedes.
Gas to diesel engine swap Vasili General Mercedes-Benz 6 06-03-2008 09:06 AM
Gas to Diesel engine swap, can it be done? wallymanE300D General Mercedes-Benz 5 12-11-2007 09:22 PM
Diesel engine oil for gas Mercedes engine?? why? ProV1x General Mercedes-Benz 2 11-06-2006 10:27 AM
Q about changing a gas engine to diesel PGreen G-Class 7 12-27-2005 09:20 AM
