Suspect sensor problem - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 06-17-2008, 11:44 AM Thread Starter
Date registered: Jun 2008
I have a 2000 E320, last week I had an AC recharge service done. The AC is working fine now, but I noticed that the engine shuts off during idle every time I turned the AC on and I can not start the engine again I have to wait few minutes some time more to start the engine back up. First, is there any relation to the AC being turned on? Second what is causing the engine to shut off? Thanks.
nooreddine is offline
post #2 of 4 (permalink) Old 06-17-2008, 12:30 PM
Kajtek1's Avatar
Quoted: 1058 Post(s)
Welcome to the forum. AC itself can't kill the engine, but if the engine is having a problem performing poorly at idle and you turn AC at this time, it might overload the engine.
Do you have any error codes? Is engine showing any other problems?
Failure to restart hot engine is mostly related to failing CPS, but it is long shoot.
Kajtek1 is offline
post #3 of 4 (permalink) Old 06-17-2008, 04:03 PM Thread Starter
No, error codes, and I do not see any other problem with the engine. car has 77K miles.
post #4 of 4 (permalink) Old 06-17-2008, 05:27 PM
Musikmann's Avatar
Quoted: 5 Post(s)
Kajtek1 is making an educated guess based on a lot of W210 owners experiences. Your symptoms certainly sound like a bad crankshaft (not camshaft) position sensor. Have a look at the Stickys at the top of the W210 section and you will see this described in greater detail.
Musikmann is offline
    Vacuum=Prime suspect? BetseyBenz W123 E,CE,D,CD,TD,TE Class 14 12-26-2011 02:26 PM
    Rought idle, suspect IAT sensor Raksan W202 C-Class 1 03-12-2008 06:30 PM
    suspect engine noise BillNouj W163 M-Class 10 07-26-2007 08:18 PM
    suspect oil in my intercooler benkokes R170 SLK-Class 10 01-25-2005 08:09 AM
