help broken drive shaft - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 06-14-2008, 05:01 AM Thread Starter
Date registered: Jun 2008
Post help broken drive shaft
1983 240d help please
ive got a broken drive shaft and manual transmission linkage levers and rods broken. i am getting new parts .
1.for the drive shaft can i measure the old one ??, so that i know the new one fits correctly??
2. seems like removing the stick shift and replacing everything to the trany should work .
3.and i need 2 rubber spacers at the ends of drive shafts ?
4. any other help with this repair would be super !!
i hope some one can help me get this car on the road . thanks !!!!!!!
mrwow42 is offline
post #2 of 3 (permalink) Old 06-14-2008, 07:21 AM
Kajtek1's Avatar
Vehicle: w211 E320 wagon 4M / Bluetec / Ford SD. Seeking affordable diesel pushmower
Quoted: 1044 Post(s)
How the old drive-shaft failed?
I would suspect one of the flex disk gave up? So replacing both of them would be in order.
Are you getting OEM driveshaft?
The linkage seems to be separate problem, that I don't understand?
Welcome to the forum
Kajtek1 is online now
post #3 of 3 (permalink) Old 06-15-2008, 06:55 AM Thread Starter
im not sure how it failed , when i got it the rear was off completely and the front shaft was hanging by the center and the front disc was torn off the tranny.
what is oem drive shaft ? i was planning to buy usedparts for $300 from mercedes south california(seeing im broke and cant buy new for $1500 )they said it would match up .
anyone else can help me out it would be great espessailly on the stick shift linkage. thanks for replying Kajtek1
mrwow42 is offline
    Old car + metal fatigue = broken half-shaft matsalleh76 W201 190-Class 3 12-06-2012 08:35 AM
    help broken drive shaft mrwow42 W123 E,CE,D,CD,TD,TE Class 0 06-14-2008 04:59 AM
    Broken cam shaft Open top 380 R/C107 SL/SLC Class 3 03-23-2007 03:27 PM
    drive shaft broken Rocha G-Class 16 09-30-2005 07:21 AM
    Drive Shaft PeteO R/C107 SL/SLC Class 5 08-08-2005 06:16 AM
