No signal to AC compressor. 1994 W124 - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 06-06-2008, 07:37 AM Thread Starter
Corndog's Avatar
Date registered: Aug 2006
Vehicle: 2002 E320
Now that I have fixed my alternator I need to tackle the AC. The refrigerant was topped up some time ago and is still holding pressure, but there is no voltage to the compressor to engage the clutch. It worked fine for a while after the top-up. Any common ailments that might be the culprit?
Thanks,
Scott
Corndog is offline
post #2 of 2 (permalink) Old 07-27-2010, 11:25 PM
Date registered: Apr 2010
Vehicle: 1989 300E (124)Sold after 19+ years, 2006 E350 (211)
Check the A/C relay (behind the battery). I found some corrosion on the plug. When cleaned with light sandpaper, and replaced in the socket, the compressor came to life.
John94010 is offline
1994 C280 Turn Signal Switch or Relay ? mogmedia W202 C-Class 3 09-03-2009 10:31 AM
W124-Is there a turn signal relay? NorCalSL W124 E,CE,D,TD Class 4 03-09-2008 08:16 AM
W124 Klann Spring Compressor Rental? Sergio W124 E,CE,D,TD Class 3 11-10-2006 08:23 PM
w124 catalogue 1994 rickjack W124 E,CE,D,TD Class 0 10-26-2006 11:43 PM
W124 E500 Limited 1994 abbam W124 E,CE,D,TD Class 5 12-15-2005 01:31 PM
