» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > General Mercedes-Benz Forums > General Mercedes-Benz
Old 06-03-2008, 05:43 PM   #1 (permalink)
Date registered: May 2008
Vehicle: 2001 C180 2.0L
P0340! How to check the camshaft sensor?
Hi
I just got a P0340 code which is strange since it has just been serviced. I am already wondering if my camshaft actuator is working properly so now I am really curious. I have looked a the Internet and I checked the power to the sensor which seems fine but how to I check the wire from the ECU to the sensor. The wire connections on the ECU seems so small....
Also, if I delete the error code will it show up again next time I check. Could this code just be because the mechanic took the sensor of temporarily and the code just need to be deleted? What happens when you delete a code?
Please help
savers is offline   Reply With Quote
Camshaft sensor lnguyenh R129 SL Class 4 10-16-2007 05:46 AM
Camshaft Sensor question?? nahegedus W210 E-Class 3 08-24-2007 07:00 AM
CAMSHAFT SENSOR YOGGI W202 C-Class 4 07-20-2007 05:46 PM
Camshaft Hall Sensor?? Dolphin27 R170 SLK Class 2 01-13-2007 05:18 PM
Camshaft Sensor whitworth socket V-Class 1 11-01-2006 07:12 AM
