1988 260E - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 05-31-2008, 08:57 AM Thread Starter
Date registered: May 2008
1988 260E
My 1988 260E intermittently stalls when slowing down for a turn or when rolling to a stop & starts back up instantly. Replaced fuel pump check valve,
fuel filter, fuel pump relay, calibrated air flow meter, replaced injectors and air filter, with no permanent fix. Also cold start problem; manual acceleration required until warm up. Replaced cold start valve this morning but with no change. These seem to be common 260E issues. Would appreciate feed back from anyone who solved the stalling & cold start problems.
exit56i95@yahoo.com is offline
post #2 of 2 (permalink) Old 06-01-2008, 02:01 AM
Date registered: Dec 2007
Vehicle: '99 W210 E240, '96 W202 C180, '96 W202 C200.
Quoted: 15 Post(s)
Water Temperature sensor? Situated at rear of engine.
Vaccum hoses?
IACV hoses?
Fuel filter on side of Fuel distributor.
Checked your O.V.P relay?
Check earthing point near IACV valve on manifold for corrosion.
Ivanerrol is offline
    Just bought a 1988 260e MackMan W124 E,CE,D,TD Class 1 05-24-2008 08:50 PM
    HELP ME AGAIN! I HAVE A 1988 260E benzgrl222 W124 E,CE,D,TD Class 1 03-25-2008 05:22 AM
    Temp ? 1988 260E hcalmar W124 E,CE,D,TD Class 0 04-20-2005 05:15 PM
    1988 260e mods Rainwarrior W124 E,CE,D,TD Class 4 12-22-2003 02:18 PM
    1988 260E Guest (MBNZ) W124 E,CE,D,TD Class 1 07-22-2002 12:12 AM
