190E 2.6 ENGINE SMOKE [1987] - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 05-31-2008, 06:28 AM Thread Starter
Date registered: May 2008
Question 190E 2.6 ENGINE SMOKE [1987]
I have a 190e 2.6 [1987] 191,000 miles, this engine smokes [white/blue,white] after is hot [warmed up], can anyone give me an idea what may be the problem?
thanks
charlie
SOUNDBOY is offline
post #2 of 6 (permalink) Old 05-31-2008, 09:46 AM
E-Class Owner's Avatar
Vehicle: 2003 Mercedes Benz E500
Sure...
Blue = burning oil; which at your mileage usually means rings/valve guides.
White = ATF or coolant being burnt... you can tell the difference by the "aroma" of the exhaust, which is kind of hard to describe here.
If you are not an experienced DIYer, then have a good Mercedes tech look at the car... then you can make an informed decision as to what course of action to take.
Good luck,
JR
E-Class Owner is online now
post #3 of 6 (permalink) Old 05-31-2008, 02:53 PM Thread Starter
190E ENGINE SMOKE
I know blue/white =oil and white is coolant or trans.fluids, but this smoking does not start until the engine has run about 15 min., plugs get fouled after a time, but compression is 120 on 5 cylinders and 140 on the other.
and now i have another problem, after i run the car for 10 miles or so it starts to shut it self off, it will crank right back up, but will shut off again, when i crank it back up it may shut right off or run a 1/2 mile or so.
help
charlie
SOUNDBOY is offline
post #4 of 6 (permalink) Old 06-01-2008, 07:47 AM
Sounds like...
like a head gasket, or crack in the head, or block, that is opening up when the engine gets warmed up.
120 PSI is getting on the low side for compression, and the fouling of the plugs is not a good thing...
The only way to find out what is really going on is to pull the head.
Nothing like giving us the story in installments... a complete post of the symptoms would have been nice. Leave anything else out...?
JR
post #5 of 6 (permalink) Old 06-01-2008, 08:53 AM Thread Starter
What should the compression be? also i put some oil treatment in [restore] and the smoking slowed way down.
thanks again
soundboy
SOUNDBOY is offline
post #6 of 6 (permalink) Old 06-02-2008, 08:57 AM
Yet an other "installment"...
thanks again
soundboy
160-180 PSI for an engine in good to really good shape. I hate to tell you this, but 191K miles is getting near the end of the typical life span of this engine. Your compression and oil burning issues are indicative of this. Your car is not a V-8, or a diesel where significantly longer engine life is expected.
One thing I can tell you... nobody can diagnose your problem adequately over the Internet. You need to have a competent tech check the engine out and then form a game plan; or, just drive it into the ground. Your choice.
JR
    I just purchased a 1987 190e and I have an engine question. batalbj1 W201 190-Class 1 04-08-2008 04:46 PM
    190E / W201 Smoke Problem - Can you help me identify what went wrong here? rjsdavis W201 190-Class 1 06-19-2006 12:28 PM
    190e 1987(?) 2.3 alexdelmore W201 190-Class 4 06-01-2006 10:44 PM
    Just started parting out 1987 190e lots of interior and engine parts mespe W201 190-Class 4 11-19-2004 02:03 PM
    smoke taillights for 190E ymt W201 190-Class 2 01-07-2004 06:32 AM
