The fault code>>B1031 - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 05-30-2008, 09:35 AM Thread Starter
Date registered: Sep 2006
Vehicle: Proton Saga BLM
Send a message via MSN to jrkong Send a message via Skype™ to jrkong
Question The fault code>>B1031
Hi all,there is a c-class which the VIN is WDB2030452F014210 drove into our workshop and said the car has current leak during the engine off.i heard there is a sound which came from the fan inside the Over head control panel.
second,LIGHT SENSOR shown in the instrument cluster.The headlights was on when i turned the light switch to AUTO under the sunlight.
i ran short test by star diagnostic and found B1031 CONTROL MODULE OCP IS NOT SENDING ANY DATA. is it the OCP is the main problem?
jrkong is offline
post #2 of 2 (permalink) Old 05-31-2008, 03:52 AM
Date registered: Jan 2007
Vehicle: 2002 honda civic (sold), 2009 Mercedes ML350
Quoted: 4 Post(s)
what exactly is the issue with the car. when doing a short test you may always see fault codes which say "ocp, eis, rear sam is not sending any data on the can bus". this doesnt mean the control unit is faulty. sometimes a unit will stop sending data for a second. thats normal.
Streetglower is offline
    Fault Code #19 chtaylor W124 E,CE,D,TD Class 3 06-11-2012 07:21 PM
    The fault code>>B1031 jrkong W203 C-Class 0 05-29-2008 08:17 AM
    fault code rufflesurf V-Class 2 03-27-2007 06:08 AM
    Fault Code WEM V-Class 1 08-01-2005 04:53 AM
    Fault Code WEM General Mercedes-Benz 1 07-17-2005 01:48 PM
