2007 E280 CDI - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 05-21-2008, 02:09 PM Thread Starter
Date registered: Mar 2008
2007 E280 CDI
Hi Guys,
Im considering purchasing a 2007 E280CDI.
Just wondering if there are any issues with these cars. I have been told by some mechanics that the gearbox can give problems due to a circuit board inside.
If you can let me know of any common faults it will be greatly appreciated as I intend to keep the car to well outside its warrently period.
If the 280CDI has alot of problems can anyone recommend an alternative car in the Merc range of similar nature. A friend of mine had a 2003 E320CDI that required extensive work in connection with the gearbox and just want to check if its an issue I need to worry about but as I say any common faults please.
Thanks in advance to everyone for any help and advice.
willinot is offline
post #2 of 2 (permalink) Old 05-21-2008, 10:12 PM
Diesel Benz's Avatar
Quoted: 32 Post(s)
Was this "lots of work" with the 2003 E320CDI from the coolant leaking from the radiator to the tranny? That should concern only cars built before 9/2003 with a certain radiator make.
Not sure about the circuit board issue but there was an issue with a connector and its seals. Was an annoying oil leak but nothing serious and easy to fix. If it existed on this 2007 (built) car, it would have been fixed already. Anyway the two cars have a different tranny.
You should not need to worry about "known issues", just check that it is generally OK as if you were buying any other car and go for it.
Diesel Benz is offline
    2007 R320 CDI - Bluetec or not? rpringle W251 R-Class 2 03-25-2008 06:14 PM
    2007 R320 CDI lemon sdteb W251 R-Class 11 01-22-2008 04:35 PM
    2007 ML 320 CDI 4-matic ecurb99 The Discount Tire Direct Tire, Wheel, Brake & Suspension 2 07-25-2007 10:52 AM
    2007 E CDI Bluetec DEM123 For Sale/Wanted/Trade/Giveaway 2 10-23-2006 06:52 PM
    2007 ML CDI horsepower???? 05E500 W164 M-Class 13 09-16-2006 08:35 AM
