Go Back   Benzworld.org - Mercedes Benz Discussion Forum > General Mercedes-Benz Forums > General Mercedes-Benz
Old 05-10-2008, 08:01 PM   #1 (permalink)
Date registered: Dec 2006
Use of non-synthetic oil Vs. Mobil One
A foreign car repair shop told me I could use Castrol 20W 50 vs Mobil One 0W40 and just change the oil every 3,000 miles. Can anyone tell me if this is ok or will it create a problem? Thanks - Doug
DougMcC2 is offline   Reply With Quote
Old 05-10-2008, 08:02 PM   #2 (permalink)
Date registered: Sep 2005
Vehicle: 2002 ML320 - Capri Blue!!
Don't go there again.
http://www.benzworld.org/forums/w211...ml#post2879830
asianml is offline   Reply With Quote
Old 05-10-2008, 08:36 PM   #3 (permalink)
Date registered: Feb 2008
Cut and pasted from the Mercedes-Benz Approved Engine Oil List:
MB sheet 229.1 approved oils
for passenger cars with gas and diesel engines, used to be minimum spec for latest (98+) engines, high detergent, dispersant spec suitable for normal drain intervals. Based on ACEA A3, B3. Note 229.1 oils are not recommended for MB's latest (2002+) 4 valve gas M271, M275, M285 and diesel OM646, OM647, OM648 engines.
"Castrol GTX3 15W-40, 15W-50, 20W-50, 10W-40"
If your vehicle is not equipped with a M271, M275, M285 nor the OM646...OM648 engine; you are using the Castrol GTX3 20W-50; and the expected operating ambient temperature is above freezing (actually 20F according to Castrol), I don't see an issue unless you are instructed by Mercedes-Benz (ie. your owner manual) that it is strictly prohibited to use 229.1 spec'ed in your engine.
Castrol USA - Grades
techyiam is offline   Reply With Quote
Old 05-11-2008, 08:55 AM   #4 (permalink)
E-Class Owner's Avatar
Vehicle: 1997 Mercedes Benz E420
You didn't tell us...
what model year Mercedes you own.
If before 1998, conventional oils are fine, but 1998 onward, check the information in the above supplied links.
Do us all a favor and complete your profile listing your vehicle and location, that way we all won't have to "guess" when responding to your posts.
JR
E-Class Owner is offline   Reply With Quote
Old 05-11-2008, 06:36 PM   #5 (permalink)
MB-SV's Avatar
Date registered: Nov 2007
Originally Posted by asianml View Post
Agreed, that shop is lame.
S.
2006 ML350 white/ash
2008 C300 Sport mars red/black
2004 986S seal gray metallic/black/black
MB-SV is offline   Reply With Quote
Old 05-11-2008, 07:19 PM   #6 (permalink)
Date registered: May 2008
from 1998 and up use synthetic only. 10w-40 would be great. on amg cars use the mobil1 0w40 extended service. 20w50 is way too heavy oil for engines after 1998
Sovereignbenz is offline   Reply With Quote
Old 05-11-2008, 09:00 PM   #7 (permalink)
E430SportMB's Avatar
Date registered: Dec 2007
Vehicle: 2000 MB
My mb is my baby. Consider Mobil 1 0w40 as your doctors RX. ( Prescription ).
I believe I think, so therefore, I think I believe !
E430SportMB is offline   Reply With Quote
Old 05-12-2008, 06:18 AM   #8 (permalink)
Date registered: Dec 2002
Vehicle: 92 500SEL -01 E320T
MB fleece filter, 0-40 Mobil Synthetic/euro formula. I let the dealer change it pretty price competitive.
Peter Guenther is offline   Reply With Quote
Old 05-12-2008, 06:47 AM   #9 (permalink)
Derek Lecours's Avatar
Vehicle: B 200 & Audi A6
Why would you want to change the oil every 3000 miles using a poorer quality oil in the fist place?
Many comparative tests have established that synthetic oil gives better and longer protection.
MB have well established and researched procedures; so why do you want to go for sub-standard oil change every 3000 miles?
The increased cost of synthetic oil is small compared to what that garage is recommending.
Find another service center, fast!!!
Old 05-13-2008, 12:41 PM   #10 (permalink)
Mercedes Benz of Florida's Avatar
Vehicle: Mercedes-Benz
Send a message via AIM to Mercedes Benz of Florida Send a message via Yahoo to Mercedes Benz of Florida
Castrol oil meets MB specs.
But why are you changing it every 3, 000 miles? Man that is way too premature.
And since these biscuit heads "might" have used dinosaur oil, tell me,
How did they change out your Oil Filter? The O-rings?
Something smells here.
Stay with Full Synthetic
Change out your Oil Filter and O-Rings.
Switch to a Summer Weight Oil.
Charles
Orlando, Florida
United States of America
Mercedes Benz of Florida is offline   Reply With Quote
Another Mobil 1 high mileage Synthetic oil? cypress188 W201 190E, D-Class 26 04-15-2008 08:00 AM
Mobil SuperSyn 10w-30 Synthetic Oil BADCASE Unimog 5 09-28-2007 09:46 AM
Mobil 1 0w40 Full Synthetic shark22 R171 SLK Class 9 03-26-2006 08:12 PM
New Mobil 1 Tri-Synthetic 0-40W Ivin W163 M-Class 10 05-24-2002 07:13 PM
Mobil 1 vs. Valvoline synthetic Kent-Chicago R170 SLK Class 6 02-15-2001 03:29 PM
