» Site Navigation
» Other Sites
Links
» Tire Upgrade Garage
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > General Mercedes-Benz Forums > General Mercedes-Benz
Old 05-09-2008, 10:01 AM   #1 (permalink)
zebra100
Date registered: May 2008
Angry Help! How to identify transmission number
I have a C240 03. After I fill transmission fluid and use 722.6 dipstick I foun overfill, but after drain 2.5 Q it still overfill a lot, that's impossible. And the car is totally not engage in gears. I doubt its a custom trnsmission, please tell where to find the number type of trnasmission. I only found on the transmission number like: 203 27010000 xxxxxx on the paper id card, nothing near any of the popular 722.9 or 722.x in the normal C and E calss cars.
( I was accidentally drained 2.5 Q of transmission fluid as engine oil, then I refill 2.5 MB factory fluid. but nothing is right.)
zebra100 is offline   Reply With Quote
Old 05-09-2008, 11:32 PM   #2 (permalink)
MarcusF
MarcusF's Avatar
Date registered: Apr 2005
Vehicle: 2002 CLK430
I've counted over 20 different 722.6 transmissions. I show a C240 as using a 722.698. I'm not sure how you accidently drained 2.5 quarts, or how you confirmed that exactly 2.5 quarts were drained. However, per the WIS, the transmission fluid level is supposed to be checked at both 25 degrees Celsius, and again at 80 degrees Celsius. At 25 degrees Celsius, the fluid level should be between the Min and Max settings that are at the end of the dipstick. With the fluid at 80 degrees Celsius, the fluid level should be between the Min and Max settings that are further up the dipstick. If the fluid was added, checked, and the temperature was ignored, it could result in problems.
IHTH
MarcusF is offline   Reply With Quote
Old 05-10-2008, 12:08 AM   #3 (permalink)
Diesel Benz
Vehicle: W211 E320CDI & V221 S320CDI
I guess you did find the tranny part number
http://www.detali.ru/cat/oem_mb2.asp...SGR=015&SGN=01
From your data card you should find the transmission serial number. You can confirm then that the tranny is original for that car. It also includes the tranny model number.
Mercedes-Benz Club Russia | Mercedes-Benz / VIN
Diesel Benz is offline   Reply With Quote
Old 05-11-2008, 03:51 PM   #4 (permalink)
Streetglower
Date registered: Jan 2007
Vehicle: 2002 honda civic
are you sure you are inserting the dipstick in the tranny tube? the dipstick tube for the engine oil is right next to it. and if you check the engine oil level with the tranny dipstick it will be overfilled.
Streetglower is offline   Reply With Quote
Transmission number laksa W210 E-Class 2 01-01-2008 10:27 PM
How to identify A/C compressor number krasnit W124 E,CE,D,TD Class 0 10-01-2005 05:37 PM
Transmission serial number sjtymko G-Class 1 02-16-2005 01:19 PM
Transmission model number? Fluid? ninjamonkey W140 S-Class 4 06-14-2004 04:34 PM
How to identify the spring's shim number? Guest (MBNZ) W203 C-Class 3 01-25-2002 01:12 PM
