Correct PSI to use? - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 05-03-2008, 02:52 PM Thread Starter
Date registered: Apr 2008
Correct PSI to use?
MB recommends 30psi for the back and 28psi for the front I think it is on our 230k. Got 4 new tyres of late, the car shop set the 4 at 32psi which is what the tyre manufacturer recommends. Which is the best to use? With gas prices I don't want to be using the wrong psi!!
joedeane is offline
post #2 of 4 (permalink) Old 05-03-2008, 05:24 PM
Date registered: Jun 2007
Vehicle: 1995 SL 500 2005 SL500
Quoted: 8 Post(s)
Use what MB recommends.
Lee Wireless is offline
post #3 of 4 (permalink) Old 05-03-2008, 05:40 PM
MB-SV's Avatar
Date registered: Nov 2007
Quoted: 77 Post(s)
I agree. Then later you can add a couple of pounds if you prefer slightly sharper handling and economy. Note: check pressure when tires are cold/before driving.
Generally the pressure shown on the sidewall is the maximum allowable psi, not the recommended pressure.
S.
2013 Mercedes C250 Sport package PLUS steel gray metallic/black
2007 Lexus IS350 Sport package smoky granite mica/gray (+F-Sport, etc.)
2010 Honda Civic GX (CNG) white/tan
MB-SV is offline
post #4 of 4 (permalink) Old 05-03-2008, 06:34 PM
Musikmann's Avatar
Quoted: 6 Post(s)
My door sticker recommends 27 all around under normal conditions and I have tried that, and also 28, but I prefer 30. People here have said the MB specs in Europe are higher, and that the lower ones we see here are because most Americans want a softer ride.
I say phooey to that. If I wanted soft I would be driving a big Cadillac or Lincoln.
Musikmann is offline
    Tires and PSI stillf1y W163 M-Class 11 12-11-2007 08:05 PM
    Ideal PSI? inspirational The Discount Tire Direct Tire, Wheel, Brake & Suspension 0 12-05-2007 10:21 AM
    NEW 19" RIMS INSTALLED... whats the correct PSI? mbnz230 W140 S-Class 11 02-16-2006 08:23 PM
    255/45/18 PSI AmoS500 W140 S-Class 0 04-05-2003 09:16 AM
    Is the H3 PIAA Super Plasma the correct foglight bulb? How does it look? Plugs right in, correct? Eric C208/A208 CLK-Class 6 12-28-2001 11:52 AM
