190E Turn Signals - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 04-29-2008, 07:08 AM Thread Starter
Date registered: Apr 2008
190E Turn Signals
I have a problem with the turn signals on my 84 190e 2.3. I tried the turning on the turnsignal and then turning on the safety flasher then turning it off which fixed my original problem of both turn signals not working.
Now the right turn signal is not working and making a slight buzzing noise when i turn it on. I am thinking that I just need to replace the hazard light switch. Could this be caused by anything else. Help!
Bennys84benz is offline
post #2 of 4 (permalink) Old 04-29-2008, 10:03 AM
MTI
MTI's Avatar
Vehicle: '85 2.3-16 '99 C280 '11 GLK350
When both left and right turn signals don't respond, then the standard test is to see if the hazard switch activates the signals. If they respond, then it rules out the electrical circuit, which covers the fuse, bulbs, grounds and flasher relay. The hazard switch is the usual culprit.
MTI is offline
post #3 of 4 (permalink) Old 04-29-2008, 12:30 PM Thread Starter
Would a bad hazard switch account for only one turn signal not working. I am also having a problem with the intermittant wipers. The slow and fast constant speed on the wipers currently work but the intermittent does not. I am thinking that it may be the combination relay. Because the wipers, hazard, turn signals and the rear defrost is on that relay. I also believe that the rear defroster does not work either. I was told by a MBZ parts guy that only parts of that combo relay can go out leaving some functions working properly ie.. left turn signal and flashers. Can this be the case?
post #4 of 4 (permalink) Old 04-29-2008, 02:24 PM
MTI
MTI's Avatar
With those added symptoms it could be the combination relay . . . or the multifunction stalk on the steering column. It's easiest to remove, inspect, clean and reseat the combo relay in the fuse box to see if it's just a bad electrical contact. I would also remove and clean the hazard switch also.
MTI is offline
Turn signals BikerBenz R129 SL-Class 2 02-16-2008 01:14 PM
Smart Key Combination to Turn off Turn Signals Magic Man General Mercedes-Benz 0 09-10-2007 09:04 AM
my turn signals wont turn off SLICKSLK007 W203 C32 AMG, C55 AMG 2 10-18-2006 06:06 PM
For once and for all, what is bulb size of rear turn signals and front signals? Black98SLK230 R170 SLK-Class 5 01-27-2004 09:15 AM
Turn Signals BrabusNYC W220 S-Class 0 01-15-2004 10:52 AM
