2001 E320 Transmission Leak - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 04-23-2008, 07:40 PM Thread Starter
Date registered: Apr 2008
I've posted this before with no replies...does that mean it's out of the "DIY" league? If not, please HELP!
I have tranny fluid leaking from the gear selector lever located toward the rear of the tranny on the driver's side. Transmission is a 722.6. What's involved in removing the lever and replacing the seal and/or bushing? On attached, lever is part #25 and seal is#30. Thanks.
2001 E320 Wagon
maudeb is offline
post #2 of 2 (permalink) Old 04-27-2008, 08:10 AM
Date registered: Jan 2007
Vehicle: 2002 honda civic (sold), 2009 Mercedes ML350
Quoted: 4 Post(s)
to replace that seal, you need to remove the trans pan, and remove the valve body. once that is done, there is a t30 torx holding the parking pawl (number 20), you remove it and you pull out the lever. then remove and replace the seal. now you will need to drop the tranny down from the rear to have room to do the seal. not remove the tranny, just drop it down.
Streetglower is offline
    ML 320 A/C drain leak (2001) dheath W163 M-Class 4 08-14-2015 05:07 PM
    E320 Transmission Leak maudeb W210 E-Class 0 04-19-2008 06:28 AM
    E320 Transmission Linkage Seal Leak maudeb W210 E-Class 1 04-18-2008 04:04 PM
    oil leak: 2001 ml 320 benzmoy W163 M-Class 6 01-11-2008 07:25 AM
    E320 transmission leak question dgaynor W124 E,CE,D,TD Class 1 03-01-2006 01:37 PM
