MB C180 1995 Overheating - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 04-23-2008, 12:28 AM Thread Starter
Date registered: Apr 2008
Hiya, I own a 1995 c180 which seems to be overheating in traffic, it runs just above 80 degrees most of the time. When in rush hour trafiic, it climbs to around 110, which, to say the least is a little worrying. I have changed the viscous fan, which made no difference at all. the fan was taken from my spare C180, which is known to be working. The other strange thing is, that when i stop with the heat that high, and check under the bonnet, the fan hasn t cut in. even though its a known working one. Also, does anybody know where the coolant temperature sensor is located as i may try that next. I have a whole spare crashed car, so parts aren t a problem. Any help would be greatly appreciated. Regards Dave The Hot
donks007 is offline
post #2 of 5 (permalink) Old 12-16-2008, 08:30 AM
Date registered: Dec 2008
I have that problem too...
..with my C180 1996. Have changed the fan and the fluid and so on. Any ideas?
DrEspenA is offline
post #3 of 5 (permalink) Old 12-16-2008, 09:56 AM
Date registered: Feb 2008
Vehicle: 2004 W220 (S430) ; 2001 R129 (SL500) Sport
Location: Alabama Gulf Coast--formerly Charlottesville, VA
Follow the wiring from the fan. That should lead you to the switch which may or may not also be the temperature sensor. If it isn't, follow the wiring from the switch. It's like ET following the Reese's Pieces; you'll eventually find your way home. Hope this helps.
"Don't pick a fight with an old man. If he is too old to fight, he'll just kill you."--John Steinbeck
DrJfrmLA is offline
post #4 of 5 (permalink) Old 12-17-2008, 10:27 PM
jboymagno's Avatar
Date registered: Sep 2008
Vehicle: 2000 e240 facelift
Mine is w201! just wanna share my experience maybe it might help. I also have the same problem few months ago, my viscous fan was the problem. I overhauled the radiator, fixed the fan and checked for leaks.
Now its back to normal.
Check the viscous fan if it's rotating perfectly.
jboymagno is offline
post #5 of 5 (permalink) Old 03-16-2009, 02:02 PM
Date registered: Mar 2009
Exclamation overheating a n 95 c180
i have same problem im not a mecanic so please explain what i need to do to stop it jumping up i have to run mine witht eh heaters on all the time to sop it flying up past 80 i dont have any probs with milky round the cap but i cannot find anysensor i look under bonnet and the fan does saem to be moving round any help will be good iof possable thanks pete
pwcomputers is offline
    1995 C36 vs. 1995 C280 wiring harness M104-AMG W202 C-Class 6 01-24-2016 06:04 AM
    1995 e420 vs. 1995 500 SEL Shyamalr W124 E,CE,D,TD Class 7 02-25-2007 04:16 PM
    1995 C180 Test Drive BarneyBenz W202 C-Class 3 09-20-2006 07:25 AM
    S500 1995 overheating problem vtormey General Mercedes-Benz 2 07-30-2006 11:11 AM
    1995 Mercedes C180 Elegance Auto dawesta General Mercedes-Benz 0 03-30-2005 12:51 PM
