ABS LIGHT AND SRS LIGHT ON - Page 2 - Mercedes-Benz Forum
post #11 of 12 (permalink) Old 08-28-2008, 09:44 AM
dmlawsonesq's Avatar
Date registered: Jun 2007
Vehicle: 2000 E320 Sedan
Originally Posted by vvrjrlaw View Post
I'm a bit confused. If there is dirt on the sensors why not clean them off with air or soft paint brush. If sensors are sealed they shouldn't be dirty. I'd look to eliminate the easy fixes first. Your brakes could be fine, but if no brake lights that is telltale on the issue of the brake light switch and failure there throws the same lights. Check your brake lights when the dash lights go on.
What I am saying is that the mechanic says the brakes are fine. There is something, however, that is making the sensors trip that is not a problem with the brakes themselves. He said could be dirt or a bunch of other things. The sensors reset on restart. He told me not to worry about it unless the sensor trips again when you start the car and keeps on doing it. At that point it is time to replace the sensors. Again, nothing wrong with the brakes, just the stupid sensors. Mucho $$ to replace.
dmlawsonesq is offline
post #12 of 12 (permalink) Old 09-04-2008, 08:11 AM
Date registered: Sep 2008
Vehicle: w203 c class 4 dr saloon 01 c220 cdi
Lightbulb srs light/abs
hi,i had the same problem with my c220,it turned out to be a number of factors,one was the two front seat belt keepers and the other was a seat sensor pad on the passenger seat,common problem in europe.there is a sensor in each keeper on the front and sometimes can be reset by unplugging the 3 plugs under the passenger seat and the 2 plugs under the drivers seat but be careful as these wires are very fine and can easily break.unfortunatel i had to replace these in my car and at a cost of 1000euro.hope this wont be the case here.
oilman is offline
    abs / srs light goes on intermittently lazuli W124 E,CE,D,TD Class 10 04-30-2009 01:22 AM
    ABS & SRS Light is on. moremercedesthanu W140 S-Class 2 01-12-2008 02:33 PM
    My gear wouldnt change, ABS,ASR, SRS Light came out now can't start ...help s50632 R170 SLK-Class 0 12-09-2007 06:51 PM
    ABS acting up , srs light being funny , brakes weird, oil light sometimes flashes jimmypop W126 S,SE,SEC,SEL,SD,SDL Class 11 10-03-2007 06:04 PM
    battery light to srs light dim lit my90300E W124 E,CE,D,TD Class 9 01-15-2007 06:46 PM
