Servicing pneumatic lock (how to unplug Yellow tube) - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 04-20-2008, 09:31 AM Thread Starter
alexus.one's Avatar
Date registered: Jun 2007
Vehicle: C280 '97, SLK55 BRABUS AMG '05, ML350 '06
Quoted: 4 Post(s)
Question Servicing pneumatic lock (how to unplug Yellow tube)
Hey all, I have some trouble w/ my trunk not opening when i press open trunk button on the dash board (I have W202). I asume that just a gears or something got stuck since I see voltage (curent increase) when trunk is not opened by tutton is pressed, so I wantto take out the lock and play with it. The problem is that lock has pneumatic Yello tube comming to it and I don't know anything about pneumatic locking system. So got couple of questions:
1) how can I disconnect the yellow tube from the lock? I see there is a socket but I dont wanna brake it and loose hermetization afterwards.
2) If I remove the lock, and unplug yellow tube will it case any problems?
3) How the compressor works? Is there any pressure in the tubes when car is off? Is it pumping pressure when I lock/unlock or is there some sort of tank that has compressed air in it?
4)Any other potential problems that I didnt even think of?
Thanks a lot for your help!
alexus.one is offline
door lock: how to disconnect from pneumatic hose and door handle? good1 W210 E-Class 5 08-20-2016 06:17 PM
How do I unplug the auxiliary water pump? rph74 W126 S,SE,SEC,SEL,SD,SDL Class 8 03-08-2008 01:39 PM
low coolant on when washer sensor unplug ? Thierry2000clk R129 SL-Class 8 11-28-2007 12:30 AM
how to unplug throttle body hayabusarider W163 M-Class 1 12-14-2006 08:20 AM
Remomval of Diff lock selector tube and selector sleeve from axles petermerle G-Class 2 06-21-2003 11:38 PM
