GAS PUMP TIPS for BENZ Owners - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 04-19-2008, 06:47 AM Thread Starter
MY2008ML350's Avatar
Date registered: Mar 2008
Exclamation GAS PUMP TIPS for BENZ Owners
This article was e-mailed to me by a friend from California. I don’t know the validity of the statements so I’m leaving it up to you to verify or criticize.
If this article’s statements are true, then at least I was able to help members of benzworld.org.
Here you go:
GAS PUMP TIPS
I don't know what you guys are paying for gasoline.... but here in California we are also paying higher, up to $3.50 per gallon. But my line of work is in petroleum for about 31 years now, so here are some tricks to get more of your money's worth for every gallon..
Here at the Kinder Morgan Pipeline where I work in San Jose , CA we deliver about 4 million gallons in a 24-hour period thru the pipeline. One day is diesel the next day is jet fuel, and gasoline, regular and premium grades. We have 34-storage tanks here with a total capacity of 16,800,000 gallons.
Only buy or fill up your car or truck in the early morning when the ground temperature is still cold. Remember that all service stations have their storage tanks buried below ground. The colder the ground the more dense the gasoline, when it gets warmer gasoline expands, so buying in the afternoon or in the evening...your gallon is not exactly a gallon. In the petroleum business, the specific gravity and the temperature of the gasoline, diesel and jet fuel, ethanol and other petroleum products plays an important role.
A 1-degree rise in temperature is a big deal for this business. But the service stations do not have temperature compensation at the pumps.
When you're filling up do not squeeze the trigger of the nozzle to a fast mode.
If you look you will see that the trigger has three (3) stages: low, middle, and high. In slow mode you should be pumping on low speed, thereby minimizing the vapors that are created while you are pumping. All hoses at the pump have a vapor return. If you are pumping on the fast rate, some other liquid that goes to your tank becomes vapor. Those
vapors are being sucked up and back into the underground storage tank so you're getting less worth for your money.
One of the most important tips is to fill up when your gas tank is HALF FULL or HALF EMPTY. The reason for this is, the more gas you have in your tank the less air occupying its empty space. Gasoline evaporates faster than you can imagine. Gasoline storage tanks
have an internal floating roof. This roof serves as zero clearance between the gas and the atmosphere, so it minimizes the evaporation. Unlike service stations, here where I work, every truck that we load is temperature compensated so that every gallon is actually the exact amount.
Another reminder, if there is a gasoline truck pumping into the storage tanks when you stop to buy gas, DO NOT fill up--most likely the gasoline is being stirred up as the gas is being delivered, and you might pick up some f the dirt that normally settles on the bottom. Hope this will help you get the most value for your money.
MY2008ML350 is offline
post #2 of 4 (permalink) Old 04-19-2008, 07:41 AM
Date registered: Sep 2006
Vehicle: 2015 S550 222
Send a message via AIM to platt-deutsch
platt-deutsch is offline
post #3 of 4 (permalink) Old 04-19-2008, 10:50 AM
Musikmann's Avatar
Quoted: 6 Post(s)
MY2008ML350,
This makes perfect sense to me, thanks! Now I'll read the link in the next post which looks like a critique.
Musikmann is offline
post #4 of 4 (permalink) Old 04-19-2008, 10:58 AM
Musikmann's Avatar
Quoted: 6 Post(s)
Platt-Deutsch,
This was good too so thanks for the Snopes.com link.
    M119 Water Pump Replacement - any tips? rsmcmahon W140 S-Class 3 10-16-2010 11:58 AM
    Gas stations for W204 owners. disbthai W204 C-Class 8 03-02-2008 09:23 AM
    Gas Won't Pump akm714 W163 M-Class 3 11-23-2007 11:28 AM
    Oh, well… (Gas owners please read) jdc1244 W123 E,CE,D,CD,TD,TE Class 8 01-06-2007 09:00 PM
    Broken gas pump, gas gushing out!! TopDownSLK R170 SLK-Class 8 12-29-2004 11:48 AM
