Engine or Fuel Problem? - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 04-15-2008, 10:48 PM Thread Starter
Date registered: Apr 2008
My name is Shawn and I have a 1990 Mercedes 300. Three days before I was to deploy I was driving to work and got about three blocks away and the car just died. It was very hessitant on starting back up and when it did it was spitting and sputtering and I had to keep it at a high RPM just to get home. To me it sounded like bad gas because it was winter, so I put some HEAT in the tank and changed the fuel filter but then it did it again this time 4 or 5 blocks away. Now it is like something is failing when it heats up. But I do not know if it is a fuel pump or ignition problem. And before I spend alot of money on one and not having it be the problem I want to be certain it is the right part I am replacing. Any help you can send my would be greatful, I get back home in 10 days.
shawn r is offline
post #2 of 6 (permalink) Old 04-16-2008, 05:34 AM
Michael Pillay's Avatar
Date registered: Oct 2003
Quoted: 81 Post(s)
Please be more specific as to the model. What are the letters after "300"?
Mike
Michael Pillay is offline
post #3 of 6 (permalink) Old 04-16-2008, 06:35 AM
Kajtek1's Avatar
Quoted: 1163 Post(s)
Is it one of 300 diesels?
Those are common for exposing fuel (air into fuel lines) leaks at cold temperatures.
Kajtek1 is offline
post #4 of 6 (permalink) Old 04-16-2008, 12:09 PM
Quoted: 81 Post(s)
How do you know it is a diesel? Is it the "Heat" thing? I have never owned a diesel. I was thinking it could be a 300E or a 300SE/SEL or 300SDL. Not sure if the 300TD was made in 1990.
Mike
post #5 of 6 (permalink) Old 04-16-2008, 09:34 PM
Kajtek1's Avatar
Theoretically it could be 19 years old gasser, but what are the chances?
Diesels on the other hand..... let's just say that about 90% of Mercedes diesel sold in last 30 years are still on the road.
Kajtek1 is offline
post #6 of 6 (permalink) Old 04-17-2008, 06:27 AM
Quoted: 81 Post(s)
There are a few 300SE/SEL still around. I have one. But really what I was after with my post was to direct our new member to the appropriate forum. I figured a search of the w124 or w126 might help with his problem......do both the 300E and 300SE/SEL have the M104 engine in them?
Mike
    300e W124 M103 engine, fuel pressure regulator problem? up2nogood W124 E,CE,D,TD Class 3 04-23-2014 07:24 PM
    The Ultimate Solution to the Fuel Gauge/Fuel Sending Unit Problem jengel111 W163 M-Class 4 03-10-2013 12:22 PM
    bad fuel? problem with fuel injectors? tmpleton88 W203 C-Class 5 08-08-2007 05:26 PM
    Low Fuel indicator blink and Check Engine Light problem... doraemon R170 SLK-Class 4 10-10-2003 07:26 PM
    Update on Fuel Gauge Problem: Got Fuel Pump Replaced Today tjhsiao W163 M-Class 4 10-25-2002 05:47 PM
