C230K Service A - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 04-13-2008, 01:51 PM Thread Starter
Date registered: Apr 2008
Smile C230K Service A
Hello folks, new to the forum, my wife and i drive a 230k, the onboard computer is telling us a Service Type A is due, actually it's 200 past due. We live in NW Florida, I have two quotes from MB dealers to service it. $250 and $295. Sound about right? My other question is with rgds the mileage, we have 47,000 on the clock since we bought it from new in '03, any major work need be done about now? We had new brakes fitted a few months back and the previous service which was done was a Type B which I believe is a Major Service? Until now all our services were covered under the 4 year warranty. Thanks!!
joedeane is offline
post #2 of 8 (permalink) Old 04-13-2008, 02:03 PM
MarcusF's Avatar
Date registered: Apr 2005
Vehicle: 2002 CLK430
My local dealer is currently charging $159, but they seem to charge less than most dealers. As for what you need to have done, that should be in your service booklet. According to my CLK booklet:
  • Every 2 years replace the brake fluid
  • Every 3 years replace the coolant.
  • Every 4 years or 50,000 miles check the condition of the flex discs.
  • Every 4 years or 50,000 miles retorque the steering gear bolts.
  • Every 4 years or 60,000 miles replace the fuel filter.
  • Every 4 years or 60,000 miles replace the air filter elements.
  • Every 4 years or 60,000 miles check the condition of the fuel filter nozzle seal in the filler neck.
  • Every 5 years or 100,000 miles replace the spark plugs
You may want to have the transmission fluid and filter changed. That's $190 at my local dealer
MarcusF is offline
post #3 of 8 (permalink) Old 04-14-2008, 03:47 PM
MTI
MTI's Avatar
Vehicle: '85 2.3-16 '99 C280 '11 GLK350
The "A" service is a glorified oil change. It took me 40 minutes yesterday to do it on my C280. 8 quarts of Mobil 1; fleece oil filter, cabin filter, and air filter. All other fluids inspected, none needed topping off. Like you, I had my rotors and pads replaced six months ago and had a new battery 8 months ago.
MTI is offline
post #4 of 8 (permalink) Old 04-20-2008, 01:56 PM Thread Starter
Thanks folks. I figured the A was basically an oil change. We had a mechanic do it and got a breakdown of what he did. Cost $229 plus tax. I know, not cheap, wish I could do the job myself. It's cheaper though than what the dealers round here would charge. We had a bad experience with one a few months. Tried to tell us we had front suspension problems which was going to cost us $960. Got a second opinion. Absolutely nothing wrong with it. Crazy stuff. We sent the dealer and MBUSA an email about our experience and got the usual BS reply!
Another question. The mechanic told us the B service was coming up on 48,000. Now we just had this A done on 47,000. Seem odd? Said it had something to do with the onboard computer settings, that it goes either by the mileage or the time, whichever comes first. So he told us the onboard computer might come on at 48,000 saying a B service is due. Can this happen or is it a scam? Thanks!
joedeane is offline
post #5 of 8 (permalink) Old 04-21-2008, 05:26 AM
Date registered: Jan 2004
Quoted: 32 Post(s)
When you do a service you reset the computer settings. It's in the owner's manual and your mechanic should know how to do it.
Len
sokoloff is offline
post #6 of 8 (permalink) Old 04-21-2008, 07:02 AM
Musikmann's Avatar
Quoted: 6 Post(s)
Originally Posted by sokoloff View Post
When you do a service you reset the computer settings. It's in the owner's manual and your mechanic should know how to do it. Len
What Len said. Most, if not all, modern Mercedes have the Flexible Service System (FSS) that needs to be re-set during a service. It not only counts your mileage until next service due, but also is comprised of sensors that monitor the condition of your oil.
You should not be due for the next FSS monitored service for about 10,000 miles IF he re-set the counter to 0 miles during the last service. You'd better do it yourself because if he knew to do it, and how to do it, surely he would have.
Musikmann is offline
post #7 of 8 (permalink) Old 04-23-2008, 07:02 PM Thread Starter
Ya, they reset the computer so it shouldn't come on for 10k you think? They seemed to think it may come on at 48k for a B!! I hope not. O they said it would cost $450, what does a B service involve? Thanks!
joedeane is offline
post #8 of 8 (permalink) Old 04-25-2008, 08:56 AM
Vehicle: 2007 C230 Sport (RWD)
copied this from another thread
B SERVICE (~ $379.95 + tax) :
- Inspect windshield wiper inserts and service windshield washer system (Replacement of wiper inserts additional*).
- Inspect and rotate tires, record tread depth, and correct tire pressure. (Wheel balance additional*).
-excludes AMG, Sports Models, SLK, and vehicles
with staggered wheels
- Engine oil change and oil filter replacement
-Includes Mobil 1 synthetic oil
- Lubrication service
- Includes hood hinges, lock cylinders, striker
plates, sun roof tracks and top off all fluids
- Cooling system inspection
- Includes antifreeze protection level, hoses and
clamps
- Brake inspection
- Includes check of pad thickness and condition of
discs, fluids and lines
- Inspect heating and ventilation dust filter, replace if needed. (Replacement additional*. Dust filter prices vary by model)
- Function check
- Includes warning lamps, headlights, exterior
lights, seat belts, windshield wiper and washer
- Inspect and lubricate throttle linkage
- Check and clean air filter
- Reset flexible service system counter
- Inspect front axle ball joints; check steering play and power steering clutch; and rear differential levels
- Inspect Poly V-Belt for condition
- Inspect starting and charging system and service battery
- Inspect climate control refrigerant
* Not included in total
thareek is offline
    C230K Service Manual C230Jeff W203 C-Class 4 05-03-2009 02:46 PM
    Service A on a Used 2005 C230K SS tmsiegle W203 C-Class 5 04-11-2008 12:47 AM
    Anyone try to fit a 05 c230k front bumper on a 04 c230k? ohhmickaay W203 C-Class 1 11-27-2007 04:43 AM
    Dealer service:BG Fuel/Air Induction System Clean-up Service Michael Pillay General Mercedes-Benz 2 10-07-2006 08:25 PM
    Reseting the flexible service system. Does the service manual lie once again? wallywalt R170 SLK-Class 0 09-09-2005 11:02 AM
