Snapping head bolts - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 04-12-2008, 09:01 AM Thread Starter
Date registered: Aug 2007
Snapping head bolts
Hi all,
The repair of my C250D continues to be an enigma to me
Today I went to fit the reconditioned head with a new gasket set, all was fine until I wen to torque down the bolts -
I progressively went in sequence tightening the bolts 4/5 times with the (new) torque wrench set at 5ft lbs the lowest it will go, (Haynes recommend 11ft lbs for stage one) I kept tightening but nothing, the wrench didnt 'click' instead one of the bolts snapped
Picture below is of the bolt and wrench (setting has moved at bit but it was on 1) The bolts are not new as they are within 1mm of the stretch tolerances.
spock500 is offline
post #2 of 2 (permalink) Old 04-13-2008, 06:27 AM
DEVOURS's Avatar
Date registered: Dec 2006
Vehicle: 2006 B 200 & Audi A6..
Quoted: 78 Post(s)
What size of bolts are they and what is the recommended torque?
You're showing more than 1 broken head bolt.
For 5 ft/lbs??....... How hard were you pulling on the torque wrench!!
You should have a feel that you're pulling to hard.
Your pics show necking at the fracture site and you can see the threads stretching before the actual failure.
Time for a new torque wrench!! Good Luck!!
It's much easier for all if you post pics of 800x800 and then we don't have to scroll into our neighbors yard to view them.
DEVOURS is offline
    How to tighten the head bolts bigwiki W124 E,CE,D,TD Class 10 09-25-2007 12:59 PM
    cylinder head bolts origan W124 E,CE,D,TD Class 0 05-11-2007 06:00 AM
    head bolts overtightened ben merc W124 E,CE,D,TD Class 6 10-28-2005 08:41 PM
    m102 head bolts 230emercedes General Mercedes-Benz 6 06-04-2005 07:54 AM
    Head bolts 500SE hoggy W126 S,SE,SEC,SEL,SD,SDL Class 0 03-23-2003 03:25 PM
