1996 E230 Earth Problem (maybe) - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 04-10-2008, 01:03 AM Thread Starter
Date registered: Apr 2008
I have a Mercedes E230 1996 and it wll not start on its own. The starter motor clicks when I turn the engine over as if has jammed, and the battery is fully charged. However If I get a jump start from another car,the car starts up straigh away despite the other car not even running. so this rules out the stsrter motor being jammed. I think it maybe an earth connecting as it was fine the other day when I parked up and now its not running and the battery isnt losing any charge. can someone point me in the direction of earth points to check.
Your help is appreciated.
hoodycrow is offline
post #2 of 3 (permalink) Old 04-10-2008, 02:22 AM
Kajtek1's Avatar
Quoted: 1057 Post(s)
Earth meaning power ground?
Sounds like you have bad cable connection somewhere. You can track the cables with control light, or voltmeter when somebody clicks the ignition.
Most likely that would be battery clamps. Also look for some sign of the heat on the cables.
BTW Welcome to the forum.
Kajtek1 is online now
post #3 of 3 (permalink) Old 04-10-2008, 02:43 AM
Date registered: Jan 2007
Vehicle: 2002 honda civic (sold), 2009 Mercedes ML350
Quoted: 4 Post(s)
just cause your battery has a full charge doesnt mean its strong enough to start the car. your battery may be dropping too many volts to start the car. the starter draws alot of amps at startup and if one cell in the battery is weak, the amperage is enough to kill the battery. i can already say that because if you connect to another battery to start and it starts, your battery is too weak. try changing your battery and test it again. if you have a meter see what the voltage is at the battery while you try to start.
Streetglower is offline
    My 1997 E230: SRS light on, problem? d52232dole W210 E-Class 0 06-10-2007 07:07 AM
    MB e230 1996 Radio Code! eJuicy Audio & Telematics Forum 13 03-15-2007 08:53 PM
    Merc E230 1996 P - Where is the Coolant Tank Nadster General Mercedes-Benz 1 05-25-2006 12:58 PM
    problem in E230 WALEED2 W210 E-Class 9 03-26-2006 11:31 PM
    earth problem 1960del Vintage Mercedes-Benz 0 08-17-2004 07:49 AM
