190e mesh cowl removal - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 04-05-2008, 02:06 PM Thread Starter
Date registered: Apr 2008
190e wiper not returning to stopped position
MY 190e wiper has been going a little slow, but when I turn it off it doesn't return to the proper position. It stops about 9 inches before it reaches the hood. It is almost in my eyesite. I wd40'd it and it runs a little faster. But, when I turn it off it will not return to the proper position. IT runs intermitantly, slow and fast , it is just the off position that is screwed upIs it the motor? Transmission? PLEASE HELP! Is it hard to replace the motor? Should I juts repalce it and forget about it. What is the problem? PLease help me!!! thanks turk100
turk100 is offline
post #2 of 8 (permalink) Old 04-05-2008, 02:31 PM Thread Starter
Hi Guys! I need to remove the mesh cowl under the windshield inorder to get to the wiper motor to lubricate the parts. How do I do it. Please respond today i need to fo it Sunday. Thanks turk100
turk100 is offline
post #3 of 8 (permalink) Old 04-05-2008, 04:54 PM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 735 Post(s)
Your car is equipped with a relay that parks your wiper in the proper position when turned off. Perhaps it has failed...
GeeS is offline
post #4 of 8 (permalink) Old 04-05-2008, 06:22 PM Thread Starter
where do I find this relay?
turk100 is offline
post #5 of 8 (permalink) Old 04-05-2008, 08:54 PM
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 735 Post(s)
The relay is either in or very near the fuse box.
GeeS is offline
post #6 of 8 (permalink) Old 04-06-2008, 07:54 AM Thread Starter
I removed both releays that I found next to the fuse box, but the wiper still worked, yet the blade still stops midway. I assumed the wiper wouldn't work at all if the relays were removed. Is that a correct assumption?
turk100 is offline
post #7 of 8 (permalink) Old 04-06-2008, 11:47 AM
MTI
MTI's Avatar
Vehicle: '85 2.3-16 '99 C280 '11 GLK350
Is the W201 forum not working?
MTI is offline
post #8 of 8 (permalink) Old 04-06-2008, 12:47 PM Thread Starter
I am new I didn't realize I can go to 201
turk100 is offline
    Help with drains around cowl vents Nascar Fan R/C107 SL/SLC Class 1 06-02-2007 05:19 AM
    1997 300d Undercarriage Cowl moherb W210 E-Class 0 08-17-2006 05:55 AM
    Tips on switching out cowl covers? sfdjeo W123 E,CE,D,CD,TD,TE Class 17 06-04-2006 02:16 PM
    Cowl Shake - who has it.... paulr R170 SLK-Class 6 10-28-2002 08:02 AM
    SLK32 Cowl Shake Don R170 SLK-Class 12 09-05-2001 07:09 PM
