1999 e320 Dies while driving - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 04-04-2008, 04:48 PM Thread Starter
Date registered: Apr 2008
Vehicle: 1999 e320
Hello - I have a 1999 e320. Accidentally put in a 1/2 tank of regular gas. 7 days later while driving thru city the car died. I was accelerating in between blocks, it died and started shaking until I stopped. Tried to restart immediately, no luck, it just kept trying to turnover. Tried again 1 hour later, it started right up, drove 3 blocks, died at stoplight. Tried to restart immediately, no luck, it just kept trying to turnover. Again, wait 1 hour, starts right up, this time I do everything (put in neutral at lights, etc) to make sure I'm constantly on the gas pedal the whole way home.
I hooked up OBDII and get P170 & P173 - "Fuel Trim Malfunction" Bank1 & Bank2. NO CEL light is on. Never has been.
I've read this forum and from that I believe it could be MAF (but typically there is CEL on), bad fuel injectors(?), just add fuel cleaner and keep driving, ?.
I just want to be sure it doesn't die on me again while driving down the road (ie Interstate driving).
Thanks for you advice and help.
torrey73 is offline
post #2 of 7 (permalink) Old 04-05-2008, 02:12 AM
Fix The Wire's Avatar
what is the fuel pressure? 5-6 bar are necessary.
Did you ever change the fuel filter?
Check also the engine wiring, it tends to become crumby on this model.
Fix The Wire is offline
post #3 of 7 (permalink) Old 04-05-2008, 07:52 AM
E-Class Owner's Avatar
Vehicle: 2003 Mercedes Benz E500
Ah...
that problem was well know on the W124s and very early W210 models, but was rectified well before the 1999 production date of the OPs vehicle.
Nice marketing attempt, though...
JR
E-Class Owner is online now
post #4 of 7 (permalink) Old 04-05-2008, 08:45 AM
Date registered: Feb 2008
[QUOTE=torrey73;2823720]Hello - Tried again 1 hour later, it started right up, drove 3 blocks, died at stoplight. Tried to restart immediately, no luck, it just kept trying to turnover. Again, wait 1 hour, starts right up, this time I do everything (put in neutral at lights, etc) to make sure I'm constantly on the gas pedal the whole way home.
QUOTE]
I had the exact same symptoms except that I did not use the wrong gas. Just by chance I fill up two cars within an hour of each other from the same pump. Both cars exhibited the same symptoms as yours. Resolution for both cars came only after the fuel in the tanks was replaced.
For the one car, it took me a long time to diagnose. I could improve on it by working on the car, but never really fixed it. After I figured out what was the cause, for the second car, I just replaced the fuel, and all was well.
I have not gone back to that gas station again.
techyiam is offline
post #5 of 7 (permalink) Old 04-05-2008, 11:55 AM
Date registered: Mar 2008
Vehicle: CLS550 Master Lease, 1990 300zxTT, 2000 camry
There are many things that could cause the problem you are talking about. For you adaptations it is possible its the MAF but those codes are not difinitive. You could have got a bad tank of fuel, simply using regular wouldnt cause the problems you are talking about. For a problem like this if you are not experienced at automotive diagnosis you should take the vehicle to a professional.
kyle21nluvnit is offline
post #6 of 7 (permalink) Old 04-05-2008, 08:29 PM
I would suspect that it can be quite costly to bring in a car to get fixed with a problem like what I had.
I guess what you could consider first is to used up the gas already in the tank (or as much as reasonable I suppose) if possible, and then fill it up with a high quality gas, preferrably from a gas station with a lot of traffic and is fairly new.
Then if it shows improvement, then you know what to hope for.
techyiam is offline
post #7 of 7 (permalink) Old 04-10-2008, 08:04 PM
It also could have nothing to do with fuel at all, and could be your crankshaft position sensor. They usually fail when the engine warms up, causing it to stall. Then when you let it cool for about an hour, it fires right up. ALSO, crankshaft position sensors can and will fail without setting a code or turning on the C.E.L.
benztech269 is offline
    99 e320 dies while driving torrey73 W210 E-Class 4 04-04-2008 06:33 PM
    Issue: Car Dies while Driving? milo55041 W202 C-Class 7 09-15-2007 09:12 PM
    1999 c280 just dies please help me mazda9683 General Mercedes-Benz 2 05-20-2007 09:33 AM
    1999 500SL Dies on road--twice!!! Luckyguy R129 SL-Class 12 05-16-2007 10:50 AM
    Engine dies when driving fast or up-hill privremena_adresa General Mercedes-Benz 20 11-01-2006 08:01 AM
