Coolant in trans fluid???? Help! - Page 5 - Mercedes-Benz Forum
post #41 of 42 (permalink) Old 04-04-2008, 02:47 PM
E-Class Owner's Avatar
Vehicle: 2003 Mercedes Benz E500
My understanding is...
that all torque converters were equipped with drain plugs through the 1999 production year; some 2000 model cars, produced in 1999 still have the plug installed.
If you have a 722.6 in a car produced after 01/2000, then odds are against it having a plug.
Beyond that, I dunno...
E-Class Owner is offline
post #42 of 42 (permalink) Old 04-05-2008, 07:45 AM
carminemb82's Avatar
Date registered: Mar 2006
Originally Posted by Black04C230 View Post
It should say on the bottom of the radiator.
no, it will say on the top of the radiator. your production date is within the range of those bad radiators. at the dealer we perform a glycol test that results in the amount of glycol in the trans, not just a yes or no answer. after replacing the radiator (which is a MUST) you need to flush trans really well and replace filter. if a droning or shuttering problem still exists you will need a new torque converter $$$$$$$
carminemb82 is offline
    WHICH TRANS FLUID TO USE ? msarles1 W201 190-Class 1 03-20-2008 06:26 PM
    Trans fluid benzover C208/A208 CLK-Class 6 09-09-2007 09:32 AM
    trans fluid and diff fluid replacement cost? numitor R170 SLK-Class 10 07-28-2007 09:40 PM
    what trans fluid do i need? ross h W124 E,CE,D,TD Class 4 07-25-2006 11:55 PM
    Trans fluid in coolant?? crf W201 190-Class 3 02-10-2004 06:51 PM
