Coolant in trans fluid???? Help! - Page 2 - Mercedes-Benz Forum
post #11 of 42 (permalink) Old 04-02-2008, 08:00 AM
E-Class Owner's Avatar
Vehicle: 2003 Mercedes Benz E500
I personally...
would think twice on the Mobil 1 synthetic route. Your transmission requires a specific ATF, with a specific base and additive pack, which the MB ATF provides. If you check, I think you will find that the Mobil 1 ATF is not factory approved for your unit. Using this will be at your own risk...
JR
E-Class Owner is online now
post #12 of 42 (permalink) Old 04-02-2008, 03:07 PM
Date registered: Mar 2006
Vehicle: 1999 ML320
Quoted: 311 Post(s)
JR
Remember the transmission is sealed for life.
mlfun is offline
post #13 of 42 (permalink) Old 04-02-2008, 03:20 PM
There is much debate on that one...
Even the dealer network is backing away from that position, for the most part.
50-60K seems to be the recommended change interval, utilizing OE fluid.
JR
post #14 of 42 (permalink) Old 04-02-2008, 06:55 PM
Vehicle: 1999 ML320
Quoted: 311 Post(s)
JR
Really ? Can you post a link or scan ?
mlfun is offline
post #15 of 42 (permalink) Old 04-02-2008, 07:03 PM
MB-SV's Avatar
Date registered: Nov 2007
Quoted: 77 Post(s)
JR
My local dealer is not backing away from MB's position on OE fluid, (and I'm dealing directly with a very well-informed senior member of the service staff).
S.
2013 Mercedes C250 Sport package PLUS steel gray metallic/black
2007 Lexus IS350 Sport package smoky granite mica/gray (+F-Sport, etc.)
2010 Honda Civic GX (CNG) white/tan
MB-SV is offline
post #16 of 42 (permalink) Old 04-02-2008, 07:11 PM
MTI
MTI's Avatar
Vehicle: '85 2.3-16 '99 C280 '11 GLK350
Oil in the trans fluid could also indicate a leaking main seal between the engine and trans.
As for the "lifetime" trans fluid in the post 93 cars . . . the lifetime that is meant is the lifetime of the trans, not the owner(s). Without servicing the fluid, the internals of the trans will eventually clog, overheat and scortch the bands. Those transmissions take about 8 liters of fluid and only MB fluid should be used.
MTI is offline
post #17 of 42 (permalink) Old 04-02-2008, 07:38 PM Thread Starter
Date registered: Dec 2007
So if I flushed the trans with Mobile 1 (about 6 liters) and then flushed and filled with MB trans fluid (about 8-9 liters) I could still have problems with a small amount of Mobile 1 still left in the trans?
Should I flush more MB trans fluid through the trans?
Rickw96 is offline
post #18 of 42 (permalink) Old 04-02-2008, 11:27 PM
MB USA is never going to back...
away from their "official position" on the "lifetime" ATF, as to do so would invite a plethora of law suits. The attorneys at the corporate HQ in NJ would never go for that...
No offense intended, but it sounds like your dealer likes to sell replacement transmissions... Does your "very well-informed senior member of the service staff" work on commission, or get incentive pay based upon the repair work sold to the customer?
I will tell you this much, very senior member of the service staff at my local dealer told me that my M119 engine took two spark plugs per cylinder I checked my completed invoice VERY carefully to make sure only 8 were actually charged out... sheesh.
JR
post #19 of 42 (permalink) Old 04-03-2008, 12:27 AM
Vehicle: 1999 ML320
Quoted: 311 Post(s)
I wouldn't sweat it. Mobil 1 is fine for the transmission.
Yeah, I know MB claims their transmission fluid is special but then
MB also claims it doesn't need replacement
mlfun is offline
post #20 of 42 (permalink) Old 04-03-2008, 02:48 AM
Date registered: Jan 2007
Vehicle: 2002 honda civic (sold), 2009 Mercedes ML350
Quoted: 4 Post(s)
a rear main seal thats leaking will not make its way into the transmission. the front pump seal and the rear main seal sit eye to eye, but you have the flex plate and torque converter in between. oil will not run down and into the tranny and up into the tranny. the laws of gravity take a toll here. oil will leak out through the bell housing.
Streetglower is offline
    WHICH TRANS FLUID TO USE ? msarles1 W201 190-Class 1 03-20-2008 07:26 PM
    Trans fluid benzover C208/A208 CLK-Class 6 09-09-2007 10:32 AM
    trans fluid and diff fluid replacement cost? numitor R170 SLK-Class 10 07-28-2007 10:40 PM
    what trans fluid do i need? ross h W124 E,CE,D,TD Class 4 07-26-2006 12:55 AM
    Trans fluid in coolant?? crf W201 190-Class 3 02-10-2004 07:51 PM
