What is it? Trim clip help needed. - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 03-31-2008, 04:23 PM Thread Starter
Date registered: Aug 2007
Vehicle: 1995 c220
It happens to all of us. A bit worth about 50 cents breaks and you can't find one. I have a broken trim clip for a 1995 c220 it fits the drivers door bottom trim and seal assembly. A straight solid plastic piece that has a channel on the bottom for a rubber strip and a channel at the top for a t shaped plastic body clip that pushes into the bottom of the door skin/frame. Even my MB database will not give me the detail on this bit. Any body gurus out there with help finding this bit?
euryale is offline
post #2 of 4 (permalink) Old 03-31-2008, 11:12 PM
Diesel Benz's Avatar
Quoted: 35 Post(s)
Which MB database did you look at? Any of these parts:
http://www.detali.ru/cat/oem_mb2.asp...SGR=015&SGN=01
Diesel Benz is offline
post #3 of 4 (permalink) Old 04-02-2008, 06:30 AM Thread Starter
Vehicle: 1995 c220
Thanks for your post
The part is in the assembly marked 045. I didn't find that diagram in my wis but I'm not very good at it yet. What broke is one of the nylon pins that fits the assembly to the bottom of the door. It looks like they slide into the assembly. Any help finding the pin?
euryale is offline
post #4 of 4 (permalink) Old 04-02-2008, 07:09 AM
Quoted: 35 Post(s)
Is it not part number 47 on the same parts figure?
You don't find these figures from WIS, you should use EPC.
    Trim part number needed melllis W140 S-Class 2 04-16-2007 10:36 AM
    Running Board Trim Part Needed for W463 spots350sl G-Class 1 12-09-2005 11:38 PM
    Need Interior Peice!!! Also Body trim needed :( Black_Benz93 W201 190-Class 6 09-15-2004 12:35 PM
    Bumper trim part needed 420SEL Realtor W126 S,SE,SEC,SEL,SD,SDL Class 0 02-09-2003 10:45 PM
    '96 C220 headlight, buld retaining clip, needed Guest (MBNZ) W202 C-Class 0 01-21-2002 02:05 PM
