A190 won't start - battery ok - no noise from starter - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 03-29-2008, 05:34 AM Thread Starter
dwalker3rd's Avatar
Date registered: Mar 2008
Vehicle: Mercedes A190 Elegance
just had 80000 km service from my mercedes dealer, drove from geneva to nice (2000 km) - two days later i go out to the car and it won't start. the electrical system is apparently ok - battery fine - tried jumping just in case.
when i turn the key - absolutely no noise. no clicks from the starter - nothing.
is the starter dead? is there something that could have been disabled preventing the car from starting (this is my first mercedes)?
dwalker3rd is offline
post #2 of 6 (permalink) Old 03-29-2008, 08:57 AM
DEVOURS's Avatar
Date registered: Dec 2006
Vehicle: 2006 B 200 .....& Audi A6..
Quoted: 105 Post(s)
If your starter is anything like the B class(and I think it is), you'd better be on warranty.
To change the starter on the B, you have to remove the engine and trans and steering and front tables and on and on..... Check with the nearest dealer and ....Good Luck!!! Derek
DEVOURS is offline
post #3 of 6 (permalink) Old 03-30-2008, 11:25 AM Thread Starter
dwalker3rd's Avatar
now it starts ... hmmm
two days later it started.
not at first, but after pumping the gas pedal a few times, it did start. weather was much warmer too.
so doesn't that rule out the starter?
post #4 of 6 (permalink) Old 03-31-2008, 06:15 AM
DEVOURS's Avatar
Quoted: 105 Post(s)
I don't know where you're at. Please fill in your profile.
You first said that there was nothing from the starter, now you pumped the fuel to get it to start???
Was it now turning over but not starting??
If you somehow had bad petrol or diesel, then the warm temperature would help if ice was in the fuel system.
There are additives for petrol and diesel that solve some fuel problems related to dramatic temperature changes.
Good news that it finally started though. Now off to the dealer to see if the defect codes show a problem. Good Luck!!
DEVOURS is offline
post #5 of 6 (permalink) Old 03-31-2008, 11:17 AM Thread Starter
dwalker3rd's Avatar
the first time there was nothing from the starter at all. the day it started, i heard one click. i pumped the gas a few times just in case there was no fuel in the engine - and it started right up
post #6 of 6 (permalink) Old 03-31-2008, 12:10 PM
Diesel Benz's Avatar
Quoted: 40 Post(s)
Since you don't mention, the key probably turned OK, meaning the drive authorisation worked OK.
There should be a "small click" anyway, from the starter relay (K6). You would probably not hear it inside the car. If there is no click from the starter motor solenoid, perhaps the starter relay is bad. You could measure the voltage from the starter relay to the the starter motor solenoid. If there is power to the solenoid, then that would be bad or seriously stuck (mechanically).
Diesel Benz is offline
HELP! S-320 will not start! but finally got to start with direct power to starter Newinport W140 S-Class 12 07-23-2013 12:49 PM
Battery to starter cable bluecollarpilot R/C107 SL/SLC Class 7 02-08-2008 11:05 AM
Clicking relay /Battery / starter / dead in a few hour Uboater W124 E,CE,D,TD Class 1 08-27-2006 07:04 AM
Alternator/Starter/Battery cable issue Gvigorus W123 E,CE,D,CD,TD,TE Class 26 11-10-2005 01:21 AM
Starter or battery faulty? Ridzuan W210 E-Class 1 02-28-2005 07:16 AM
