Octane for '99 CLK430 - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 03-27-2008, 09:03 PM Thread Starter
NOTABMW's Avatar
Date registered: Mar 2008
Vehicle: W208 1999 CLK430
Just recently purchased my 99 CLK430. It's a beautiful car and has been treated with the utmost care and respect. This is my first Mercedes, so there are a lot of things I do not know about my new car. Definitely a newbie.
The operator's manual calls for 91 octane. After doing a little research, I came to the conclusion that European octane ratings differ from American/Canadian ratings. I live in the USofA and want to know exactly what to put in my new cream puff.
Any insight, suggestions for a new owner, constructive criticisms, or ideas will be appreciated. Thanks for the help.
NOTABMW is offline
post #2 of 11 (permalink) Old 03-28-2008, 01:40 AM
JOE55's Avatar
Date registered: Nov 2004
Vehicle: E55 ///AMG
Quoted: 8 Post(s)
Congrats and Welcome to the Forum!
use 91 octane as recommended! or up.
JOE55
JOE55 is offline
post #3 of 11 (permalink) Old 03-28-2008, 05:37 AM
Michael Pillay's Avatar
Date registered: Oct 2003
Quoted: 86 Post(s)
The topic of which octane gas to use has been discussed many times at length. If you want to get more info, the search button in the upper right of the screen will help. As suggested use premium.
Mike
Michael Pillay is offline
post #4 of 11 (permalink) Old 03-28-2008, 06:46 AM
asianml's Avatar
Date registered: Sep 2005
There may be different methods to calculate octane rating in the U.S. and Europe, however the manual for a U.S. spec car is written with U.S. spec calculations for pretty much everything. So go with 91 octane.
2002 Mercedes-Benz ML320 (sold)
2011 Chrysler Town & Country
2008 Toyota Camry Hybrid
2003 Yamaha V-Star 650 Classic
2002 Jaguar X-Type 2.5
asianml is offline
post #5 of 11 (permalink) Old 03-28-2008, 11:26 AM Thread Starter
NOTABMW's Avatar
Sounds great guys. Thanks for the help! On another note, and I'm sure this has been covered hundreds of times on this forum - but the Standard and Winter mode switch by my shifter...it is now late March and I have had it in Winter mode since I purchased it in January...is it safe enough to place in Standard? And should this be done prior to starting the vehicle? Is Winter mode only for ice and snow conditions? Again, any info is appreciated.
NOTABMW is offline
post #6 of 11 (permalink) Old 03-28-2008, 05:55 PM
asianml's Avatar
The W/S switch only changes the transmission's shifting characteristics, shifting points, and starting gear. W starts in 2nd and upshifts earlier. S starts in 1st and upshifts later or normally, rather.
You can switch between the two as much as you want and use either whenever you want. Think of W as just assisting you in slippery conditions. The button itself controls nothing mechanical, but rather the ECU/TCU which then controls the tranny.
asianml is offline
post #7 of 11 (permalink) Old 03-28-2008, 06:16 PM
Date registered: May 2005
Vehicle: '07 GL320CDI
Quoted: 2 Post(s)
Your owners manual is for a USA car and the specifications therein are for USA gasoline.
Kent Christensen
Albuquerque
'07 GL320CDI
lkchris is offline
post #8 of 11 (permalink) Old 03-30-2008, 07:09 PM Thread Starter
NOTABMW's Avatar
Thanks for all the insight guys...I can see I have a lot to learn about the car itself. What is the typical price to replace one of the electronic keys? 2 came with the car, 1 works just fine - and the other I have to take the mechanical key out of the electronic key to lock and unlock the car - but the electronic key still starts the vehicle just fine. I bought a new lithium battery, but it is still functioning properly, and I think the unit itself is toast. Are those overly pricy to replace?
NOTABMW is offline
post #9 of 11 (permalink) Old 03-30-2008, 10:43 PM
arvy's Avatar
Date registered: Oct 2006
I got a quote of about $200 plus CAD. The valet (non-electronic) key was not much cheaper.
ARVY
1999 E430
1999 C230K
1992 300E (write-off)
1984 190D (sold)
arvy is offline
post #10 of 11 (permalink) Old 03-30-2008, 10:52 PM
LOUIZIANABOYZ's Avatar
Vehicle: 1999 Mercedes C230 Kompressor
Send a message via AIM to LOUIZIANABOYZ Send a message via Yahoo to LOUIZIANABOYZ
I use V-Power only and sometimes throw in some octance booster... And I use Winter Mode in the rain also to prevent tire spinning... But sometimes, I like to play around...
LOUIZIANABOYZ is offline
    octane camvaugeois W124 E,CE,D,TD Class 1 01-30-2008 05:02 AM
    Octane? mgill85258 W126 S,SE,SEC,SEL,SD,SDL Class 6 11-07-2006 10:23 AM
    Sunoco 91/94 octane vs. Shell V-Power 91 octane JBeans General Mercedes-Benz 4 11-13-2005 03:22 PM
    91 octane tuga11 W163 M-Class 11 09-14-2004 10:04 PM
    Follow up to Poll - Is Octane booster OK, if 94 Octane not available ? LelloSLK R170 SLK-Class 11 04-23-2002 06:55 PM
