New Tires, Wheel Alignments - Mercedes-Benz Forum
post #1 of 25 (permalink) Old 03-27-2008, 09:35 AM Thread Starter
dmlawsonesq's Avatar
Date registered: Jun 2007
Vehicle: 2000 E320 Sedan
I need new tires on a 2000 E320 that I purchased used last year. I have not owned a Merecedes before. I have typically bought tire for all of my cars at a local Goodyear dealership.
Is there anything unique to a Mercedes vehicle that would compel me to use the dealership for this? The local dealership's prices are much higher for both the tires and the installation. For instance, they want $130 to do an alignment. Goodyear quoted me $69 for an alignment. I do have an alignment issue as the tires have worn unevenly up front.
Also, any opinions on the two types of tires I am considering - Michelin Pilot MXV4 verus Goodyear Assuarance ComforTreds?
Thanks.
dmlawsonesq is offline
post #2 of 25 (permalink) Old 03-27-2008, 09:40 AM
Date registered: Mar 2008
Vehicle: CLS550 Master Lease, 1990 300zxTT, 2000 camry
First off I would definatly go with the Michellin tires. You do not need to get them installed at the dealer as long as you dont mind goodyear working on your Benz. For the alignment I wouldnt get it done at Goodyear unless they have the attachments that go into the five little holes on each of your wheels. Doing an alignment on a Benz using generic alignment heads wont help anything and could possible make the alignment worse.
kyle21nluvnit is offline
post #3 of 25 (permalink) Old 03-27-2008, 09:41 AM
Vehicle: 2000 clk320 convertible
You need to read the Tirerack forum here. They are very knowledgeable and can explain everything. I normally trust dealer with things like alignment, engine work, etc. But as far as tires go, you can get them anywhere as long as they are properly balanced using a "GSP9700 series" balancer which actually simulates vehicle weight on the tires. This is important so that if the wheels are old and bent a little you need to know that before you put on the tires and watch the steering wheel meringue on the highway every day
There is no such thing as a Michelin pilot MXV4. Also, michelins are not that good read the reviews @ tirerack.com below:
Consumer Survey Results By Category
Camsky is offline
post #4 of 25 (permalink) Old 03-27-2008, 09:55 AM
There is a Michellin pilot mxv4, also a primacy mxv4
post #5 of 25 (permalink) Old 03-27-2008, 10:38 AM
I do not see it unless if you mean energy mxv4:
Michelin Tires
Did u mean pilot mxm4?
i have heard pilot exalto is very good. it is no. 1 on consumer surveys for perf. all season. will be my choice. my buddy has it on. loves it especially in the snow, but i guess u guys do not have to worry about snow that much
Camsky is offline
post #6 of 25 (permalink) Old 03-27-2008, 11:09 AM
Date registered: Feb 2005
Vehicle: '03 CL500,& '07 GL450
I purchased my last set of tires for my 2003 CL500 from the "Tire Rack". Had the local MB dealer mount and balance them for $130. I had concerns about possible damage to the wheels if the tires where mounted by a non-MB shop. The MB dealer also had the proper wheel weights. Peace of mind was worth it to me.
'03 CL500,'07 GL450
reddog is offline
post #7 of 25 (permalink) Old 03-27-2008, 11:15 AM
JOE55's Avatar
Date registered: Nov 2004
Vehicle: E55 ///AMG
Quoted: 8 Post(s)
Well It all depends on the wheel shop you go to, If you go to Big-O or Firestone kind of shop they might damage you're rims but normally if you go to a reputable, high end wheel shop they will do a better job than MB
JOE55 is offline
post #8 of 25 (permalink) Old 03-27-2008, 11:51 AM Thread Starter
Thanks for the input. I think I am going to go with the "peace of mind" option and let the dealership do it. I misstated my tires - I have on the car the Michelin MXV4 Energy Plus. Those (or their latest version) are the ones the dealership has recommended. The local Costco shop claims those tires wear out too quickly and that is why there is no specific number of miles on its treadwear warranty. Apparrently, newer versions of the MXV4 do come with specific mileage warranties.
post #9 of 25 (permalink) Old 03-27-2008, 11:57 AM
Musikmann's Avatar
Quoted: 6 Post(s)
Goodyear here recommended their Assurance Comfort Tread for my E430 and I bought a set. I mentioned them on here and someone told me those do not have the necessary load rating for a W210. I think these all need 93 and those Goodyears were only 91. I'm sure the dealer will install what's best for your car, plus they know to torque the lugs, which I suspect a lot of shops do not.
Musikmann is offline
post #10 of 25 (permalink) Old 03-27-2008, 01:31 PM
DEVOURS's Avatar
Date registered: Dec 2006
Vehicle: 2006 B 200 .....& Audi A6..
Quoted: 101 Post(s)
Actually, my dealer rotated mine and torqued some of the bolts to 160 ft/lbs. OUCH !!!
I surely would have been stranded if I had attempted to change it myself with the little wrench that the car comes with.
It's a shame to always have to re-check the dealers work.
I knew something was up when the torque wrench never came out.
The dealer used to let you watch from behind a wall but that's now been stopped.
I got lucky with the stall location and still had a view.
Some of the dealers are definitely slipping.
DEVOURS is offline
Wheel and tires Baloococo R129 SL-Class 4 03-26-2006 02:49 AM
Looking for the guy in Escondido who does alignments? silverslk The Discount Tire Direct Tire, Wheel, Brake & Suspension 1 02-06-2006 12:28 PM
Looking for the guy in Escondido who does alignments? silverslk For Sale/Wanted/Trade/Giveaway 0 02-04-2006 11:07 AM
Looking for the guy in Escondido who does alignments? silverslk General Mercedes-Benz 0 02-04-2006 11:07 AM
Headlight alignments... Guest (MBNZ) W202 C-Class 2 05-27-2002 06:17 PM
