Indicator lights fault - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 03-24-2008, 01:52 PM Thread Starter
Date registered: Mar 2008
My V230's indicator/hazard lights have just stopped working (they don't light up at all). The intermittent wash/wipe has coincidentally stopped working. The indicator light in the instrument binacle lights up when the indicator stalk is moved up or down or the hazard light switch is pushed but it does not blink. I have changed all the bulbs (front, rear and side) and the fuses are fine. Could it be the relay (located, I believe under the passenger seat)? If so, how do you identify the relevant relay. If it is not the relay, what else could it be? Any ideas very gratefully received.
leighw is offline
    ETS light on the Dash(Fault indicator?) iriaanenih W163 M-Class 3 07-25-2007 11:33 PM
    turn indicator/hazard lights fault? silver50 R129 SL-Class 1 01-27-2007 06:28 PM
    BAS/ESP & ABS Fault Indicator Light On rca918 Vintage Mercedes-Benz 0 04-27-2006 04:18 AM
    Non-flashing indicator lights Luc SLK (UK) R170 SLK-Class 2 07-10-2005 10:49 AM
    indicator lights went haywire on me.. help JD32 R170 SLK-Class 3 04-14-2004 07:41 AM
