post #11 of 27 (permalink) Old 03-24-2008, 02:13 PM
cyberdrakon's Avatar
Date registered: Dec 2002
Vehicle: SLK55 (2006) C36 (1995)
Send a message via AIM to cyberdrakon Send a message via MSN to cyberdrakon
Ok, couple questions i've always wondered. What does factory trained mean? trained at mb training center? trained at dealer? trained in germany? trained in alabama?
how do you go about doing this? pay for classes? apply for mechanics job? apply for classes? start work, become apprentice, get recommended for training?
How's it compare to ASE?
eddie aka cyberdrakon aka drakon
SLK 55 AMG widebody (2006), C36 AMG (1995), 420 SEL (1989)
Previously: 560 SEC RennTech/AMG (1990), 420 SEL (1987).
cyberdrakon is offline
post #12 of 27 (permalink) Old 03-24-2008, 02:58 PM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 67 Post(s)
Originally Posted by MASTERBENZ View Post
I'm a BENZ fanatic/ business owner specializing in BENZ.
Ever work at the Department of Redundancy Department?
flyboyike is offline
post #13 of 27 (permalink) Old 03-24-2008, 03:28 PM
Vehicle: 2005 C350, 2002 ML270CDI, 1969 230S, previously 2002 A160, 1985 380SEC ivory, 1983 380SEC grey
I have a late 2005 C350, WDC203056.... engine M272960...
I intend to keep the car for many years as it is my "last car", my retirement present to me :-)).
I notice from other posts that the M271 enginge has a leaking oil from camshafts problem, as well as the PCV hose.
Do you know of any (similar) issues I am likely to face at high mileages?
Many thanks
Audiophile_AU is offline
post #14 of 27 (permalink) Old 03-24-2008, 04:20 PM
Date registered: Mar 2008
i have posted about my 1988 260e, it started to die while driving and then start up after a few minutes, i changed the overload relay behind the battery on the fire wall, it ran great unitl today , it started to die again, any other suggestions on what i should look for?
benzgrl222 is offline
post #15 of 27 (permalink) Old 03-25-2008, 12:07 PM
Hello Mar.. here's one for you...
Hello Mar, greetings from ther UK, here's one for you..
when I slow down to idle in my 91 300CE 24v, as i get to about 5mph and below, the revs drop down to about 300rpm, but immediately come back to about 750rpm once the car is stationary, being held on the foot brake. When I release the brake and the car starts to creep forward, the revs drop again down to about 300, almost stalling, until I push the accelerator and get up speed. When trying to paralell park with full lock on the steering the problem is worse and sometimes the engine will over compensate and quickly rev to about 1500 rpm, as if you had dabbed the accelerator, making the car lurch forwards or backwards, which is a bit hairy when you are trying to park. I have noticed that very occasionally the ABS warning light will illuminate, and when it does the idle problem dissappears immediately, and when the ABS light goes off, the problem returns immediately.
I have had the idle-control valve cleaned and checked and the OVP relay replaced with no improvement whatsoever... can you make any sensible suggestions of what to check next????
Mark Reynolds is offline
post #16 of 27 (permalink) Old 03-25-2008, 09:30 PM
Date registered: Jan 2007
i own a 2001 c320, suddenly my fog lights and parking lamps wont turn on when you unlock the car at night anymore. i checked the settings on the cluster and is set to be on. i can tell is not the sensor because my dome lights still respond. is there a fuse,relay or something that may be causing this problem??????? please someone help.
blazy269 is offline
post #17 of 27 (permalink) Old 03-26-2008, 10:48 AM
Kachuz's Avatar
How can I change the brake rotors from an ml 430, I know how to do some mechanical work, but I don’t know if you have to take out the big nut in the center? Please help!!
Kachuz is offline
post #18 of 27 (permalink) Old 03-26-2008, 02:58 PM
Adullessence's Avatar
Date registered: Feb 2008
Vehicle: 2002 Mercedes C32 AMG-(19'inch Mandrus Millenium wheels),1998 Infinity I30
My driver seat module had some work done on it because it was drawing amps from the battery. After which, though not immediately, the SRS light came on and has been on for quite sometime. I had this work done in St. Louis. I don't wanna drive all the way back out there to get them to look it over. Is there something i can check into myself before taking it back to a dealer workshop?
Ladies! My Mercedes! Holds 3 in the back, 2 if ya fat.
Adullessence is offline
post #19 of 27 (permalink) Old 04-03-2008, 06:02 AM
Date registered: Apr 2008
Vehicle: Mercedez Benz
hey anyone whos looking for a great machanic who stands behind all of his work its mar at mars automotive i took my 300CE there to get some minor work done got an estimate first off lover than anyone else and was done the same day very there very humble and take pride in what they do i'll always take my benz there keep up the great work guys!!!
CE_LOVE is offline
post #20 of 27 (permalink) Old 04-03-2008, 08:21 AM
E-Class Owner's Avatar
Vehicle: 2003 Mercedes Benz E500
Masterbenz, or Mar of Mars, on 03-22-2008 makes a post offering to help others with their MB questions and touts his repair business along the way...
Half a dozen questions get posted, none of the promised answers are proffered. Then a new member comes along and on his first post raves about Mar/Mars.
Call me a cynic, but I suspect that this was an marketing effort and nothing more. Did you take a course in marketing when you got that MBA, Mar?
E-Class Owner is offline
    Benzes n' Winter myfirstbenz Off-Topic 18 11-11-2006 01:46 AM
    Looking for advice on old Benzes 450sel6.9 General Mercedes-Benz 4 07-11-2006 11:56 AM
    What headlights do our Benzes have? H4 or H7? Or both? Rollingstone W126 S,SE,SEC,SEL,SD,SDL Class 2 11-30-2005 04:34 PM
    It's summertime! Where are all the Benzes? navydave Vintage Mercedes-Benz 0 07-16-2004 01:28 PM
    BENZES ARE BETTER Guest (MBNZ) W202 C-Class 2 02-10-2001 12:11 PM
