Interesting Problem, thoughts please - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 03-21-2008, 05:02 AM Thread Starter
patpur's Avatar
Date registered: Sep 2007
Vehicle: 2004 C240 4Matic
Last night I went out to move our 04 240 4 matic and none of the gauges were working, also no heat, none of the accessories except the door lock button. The lights do work and I ran the car around the block and it seemed to run fine. I pulled it back in the driveway and shut it off. About a minute later I restarted the car and everything worked but now I was getting a "check engine" light. Left the car for the night and tried it again this morning and same thing. Start it no gauges same deal. Shut it off, turned it back on and everything works again but there is the check engine light. My wife took the car to work which is a short distance. I will call the dealer but anyone have any idea at what we might be looking at here?
As always thanks in advance.
Pat
patpur is offline
post #2 of 7 (permalink) Old 03-21-2008, 08:46 AM
Date registered: Mar 2008
Vehicle: CLS550 Master Lease, 1990 300zxTT, 2000 camry
There is really no telling what is wrong without being able to hook up to the vehicle. Sorry man the dealer or a Benz shop is probably your only option to figure this one out.
kyle21nluvnit is offline
post #3 of 7 (permalink) Old 03-21-2008, 09:31 AM Thread Starter
patpur's Avatar
Goes in Monday. I just hope its something simple. We love the car but this back and forth is getting a bit old. If it keeps up I might have to buy a new one!
patpur is offline
post #4 of 7 (permalink) Old 03-21-2008, 11:22 AM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 70 Post(s)
Generally speaking, when you have a mass failure of seemingly unrelated components, I'd check two things:
1. Ground.
2. Hot position of the ignition switch. It seems like everything that's not working is the stuff that needs the ignition switch in "Hot" position.
flyboyike is offline
post #5 of 7 (permalink) Old 03-21-2008, 01:59 PM Thread Starter
patpur's Avatar
Thanks. If its a bad ignition switch the dealer will have to get into that. I'll check the ground but much past the one that comes off the battery I'm lost.
Fortunately the car is certified so its on MB to find it and fix it.
Pat
patpur is offline
post #6 of 7 (permalink) Old 03-22-2008, 06:41 AM Thread Starter
patpur's Avatar
Well I found the problem. The fuse box that sits by the master cyl. was not closed properly and some tree debris got in there. I blew it out, made sure all the connections were tight. One of the wire bundle connectors was a bit loose. I buttoned it back up correctly and no more problem. Car did fine last night and this morning.
Pat
patpur is offline
post #7 of 7 (permalink) Old 03-22-2008, 07:59 PM
flyboyike's Avatar
Quoted: 70 Post(s)
Pat
Imagine that.
Your thoughts on my cruise control problem Brix W202 C-Class 0 09-21-2007 04:03 PM
Interesting information on my car, any thoughts on these options? slybydesign W210 E-Class 5 08-08-2007 02:30 PM
problem with NAV, any thoughts? Carl Osborne C208/A208 CLK-Class 4 04-04-2007 05:13 PM
280GE Problem-Looking for any Thoughts Big Red G G-Class 7 01-21-2005 09:38 AM
Interesting new problem, or is it a problem? My car's water broke yesterday Jason Y R170 SLK-Class 8 06-13-2001 06:54 PM
