!997 S-320, starter and engine turns but it does not start. Any ideas? - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 03-20-2008, 06:54 AM Thread Starter
Date registered: Mar 2008
!997 S-320, starter and engine both turn but engine does not start. Any ideas?
stingray is offline
post #2 of 4 (permalink) Old 03-20-2008, 09:59 AM
Vehicle: CLS550 Master Lease, 1990 300zxTT, 2000 camry
Crank or cam position sensor probably, also could possible be fuel related. Do you have fuel pressure?
kyle21nluvnit is offline
post #3 of 4 (permalink) Old 03-22-2008, 06:56 AM
Date registered: Feb 2008
If the gasoline engine only cranks but never fires up, one of the most cost effective ways to test whether the fuel system is at fault is to spray "Starting Fluid" into the intake manifold, down-stream of the MAF. If you have not use starting-fluid before, be aware that starting fluid is extremely flammable. No one should be anywhere near the opening of where you sprayed. Although, I myself have never have anything bad happened to me personally, potentially it can. It may be prudent to wear a protective glove too.
If the fault is only due to the fuel system, the engine will start right up and runs as long as you continue to spray into the intake.
Combustion will take place if a good spark occurs at the right time, and a sufficiently well mixed air/fuel charge is present at the right ratio.
techyiam is offline
post #4 of 4 (permalink) Old 03-22-2008, 09:04 AM
Kajtek1's Avatar
Vehicle: w211 E320 wagon 4M / Bluetec / Ford SD. Seeking affordable diesel pushmower
Quoted: 1044 Post(s)
Easy way to check the fuel system is press the tire-style valve on the fuel rail, while somebody is cranking the engine. It suppose to give a good spray, while some flow might be residual pressure.
One of the way pointing to CPS is observe tachometer. If it doesn't move during the cranking, it confirms CPS fault.
Kajtek1 is offline
    HELP! S-320 will not start! but finally got to start with direct power to starter Newinport W140 S-Class 12 07-23-2013 12:49 PM
    MB 230E (W124) Starter Turns Engine, but it will not Start morganGDFP W124 E,CE,D,TD Class 0 02-03-2007 09:28 AM
    starter turns, engine doesn't lightnin Vintage Mercedes-Benz 1 10-29-2006 05:08 PM
    110cdi engine turns but won't start petesavi V-Class 3 02-27-2005 09:45 PM
    engine turns over doesnt start please help classic benz W126 S,SE,SEC,SEL,SD,SDL Class 3 04-23-2004 11:07 PM
