1990 300E - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 03-19-2008, 10:37 PM Thread Starter
Date registered: Mar 2008
Smile 1990 300E
We have a 1990 300E with a transmission not working properly. It doesn't shift properly. It has 150,000 miles on it and had not been driven much at all over the last 3 years. We understand that changing fluids and etc may not be a good idea because it may do more damage?? Can some person help tell us what to do next?
Barney is offline
post #2 of 9 (permalink) Old 03-20-2008, 06:29 AM
Date registered: Jan 2004
Quoted: 30 Post(s)
If it's not working properly now, what harm can changing the fluid/filter do? That's where I'd start. I don't buy the "if the transmission has never been serviced, then leave it alone" theory.
sokoloff is offline
post #3 of 9 (permalink) Old 03-20-2008, 10:01 AM
Vehicle: CLS550 Master Lease, 1990 300zxTT, 2000 camry
I agree with Sokoloff, you already have issues the easiest and cheapest thing to do is have your fluid and filter changed. Make sure whoever you get to change the fluid drains the torque converter as well.
kyle21nluvnit is offline
post #4 of 9 (permalink) Old 03-20-2008, 10:06 AM
Date registered: May 2005
Vehicle: '07 GL320CDI
It won't hurt anything except your wallet to change fluids. It's NOT going to fix ANY problem.
Kent Christensen
'07 GL320CDI
lkchris is offline
post #5 of 9 (permalink) Old 03-20-2008, 10:49 AM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 544 Post(s)
It could be a vacuum/modulator valve issue. Look into it, it's an easy/cheap fix if you're lucky.
GeeS is offline
post #6 of 9 (permalink) Old 04-01-2008, 09:24 AM
Date registered: Apr 2008
Vehicle: 1990 mercedes Benz 300E
i have the same model and I have a question as to what is that button down the steering console? I think it goes forward and backwards.
mcbchild is offline
post #7 of 9 (permalink) Old 04-16-2008, 11:12 AM
Avoid having it "power flushed". Try draining thru drainplug (you'll only get about 1/3 of the fluid out) and adding fresh fluid with a product called "Seafoam". If no improvement, have it drained with a filter change (again avoid power flushing). If none of this works have modulator checked/adjusted. Last resort would be power flushing it.
obfrank is offline
post #8 of 9 (permalink) Old 04-16-2008, 11:51 AM
E-Class Owner's Avatar
Vehicle: 2003 Mercedes Benz E500
Your car...
has a drain plug on the torque converter, so you should be able to get more than 1/3 of the ATF out... as indicated above, be very "wary" of power flushing.
I haven't heard of using Seafoam in the transmission, but it is a known fix for some problems when used in the crankcase, on vehicles designed for conventional [not synthetic] oils.
Also, don't forget the transmission filter.
Good luck,
E-Class Owner is offline
post #9 of 9 (permalink) Old 04-16-2008, 12:34 PM
"Seafoam" is available for crankase and transmissions. Make sure you use the transmission Seafoam and let it work in for at least 20 miles or so.
obfrank is offline
    1990 300e vs 1989 300e jfine W124 E,CE,D,TD Class 17 08-17-2015 06:02 AM
    1990 300e dstone1567 W124 E,CE,D,TD Class 3 04-20-2007 06:27 PM
    Considering 1990 300E... what to look for? alanmb W124 E,CE,D,TD Class 5 03-18-2007 08:34 AM
    1990 300e dope626 W124 E,CE,D,TD Class 1 03-15-2007 04:17 PM
    1990 300E - Please Help 300EBEnz W124 E,CE,D,TD Class 6 04-01-2006 07:14 PM
