03 R230 SL500 Help! onboard computer going crazy! - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 03-18-2008, 06:07 PM Thread Starter
98 SLK230 US's Avatar
Date registered: Oct 2003
Vehicle: 03' SL55
Lightbulb 03 R230 SL500 Help! onboard computer going crazy!
Any advice would be appreciated. This being said here is my issue. I get SOS malfunctions, ABC, electric consumers offline, ABS light comes on. When one stops another starts. Could this just be a faulty ground wire or possibly some kind of corrosion causing this. The systems all seem fine and work properly but the warnings keep coming every few weeks.
98 SLK230 US is offline
post #2 of 5 (permalink) Old 03-19-2008, 01:44 AM
Date registered: Jan 2007
Vehicle: 2002 honda civic (sold), 2009 Mercedes ML350
Quoted: 4 Post(s)
you first need to check your charging system (batteries first). the control units on your car cant handle low voltage.
Streetglower is offline
post #3 of 5 (permalink) Old 03-19-2008, 10:49 AM
Date registered: Mar 2008
Vehicle: CLS550 Master Lease, 1990 300zxTT, 2000 camry
Yes charging and starting system is very important with this vehicle. You have two batteries to run different systems at different times. I would definatly start with having the batteries checked and the charging system checked. If those test good then start looking for other problems.
kyle21nluvnit is offline
post #4 of 5 (permalink) Old 03-19-2008, 05:06 PM
if the car starts ok than its not the front battery, this battery is for starting only. More than likely it needs a new systems battery which is in the trunk. Is the light in blue or red when its on the cluster? blue = battery is low on charge. red = charging system
MB_Tech is offline
post #5 of 5 (permalink) Old 01-04-2009, 11:54 AM Thread Starter
Vehicle: 03' SL55
Disconnecting SOS
Thanks for the help! It was the rear battery. Apparently the SOS has a problem that causes the system to continuously try to call for help and that killed the battery. Any advice on disconnecting the SOS?
    R230 (SL500) Parts For Sale alexx R230 SL-Class 0 01-27-2008 04:47 PM
    Original SL500 wheels w/tires R230 WPFAST For Sale/Wanted/Trade/Giveaway 0 08-25-2007 12:02 PM
    Exhaust R230 SL500 sirrone R230 SL-Class 4 09-03-2006 09:22 AM
    560SEL rare onboard computer info needed mutley666 W126 S,SE,SEC,SEL,SD,SDL Class 2 07-16-2005 11:03 AM
    Upgrade to onboard computer Ben Kokes R170 SLK-Class 12 05-09-2002 08:17 PM
