A class semi auto gear problems. - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 03-18-2008, 02:48 AM Thread Starter
Date registered: Mar 2008
Vehicle: Sl 500/Vito/Saab 9.3/BMW E34.
Hi all. I have a 1999 A160 that has covered 100k miles and it belongs to my wife. I will have to repair it free of charge as it belongs to her and would like to ask if any of you guys can help. I read a post on this site about this very fault and I did take the ACS unit off and strip it. The bushes at the bottom of the armature seem to be ok (they are not stuck or badly worn). I did notice that the armature was very slightly stuck until I tapped it. I put it back on the car and the "F" light that was on the dash had changed to "N". I then tried to bleed the system and could not get very muck fluid out at all. I was told that you should turn on the ign with the bleed valve open and then close it and switch ign off. This was to be repeated a few times. I would welcome any help about this fault and thank you in advance.
Regards
Steve.
millspeed88 is offline
    semi automatic gear problem help Ali_c W168 A-Class 2 04-21-2016 01:30 AM
    A160 Semi Auto Problem CowsGoMoo W168 A-Class 0 01-24-2008 09:32 AM
    auto gear upshift nhaixin69 W124 E,CE,D,TD Class 7 04-26-2005 06:05 PM
    V class 280 auto box problems zenman 63 V-Class 5 03-18-2005 09:36 AM
    V Class 280 auto box problems zenman 63 General Mercedes-Benz 0 03-12-2005 10:47 AM
