It's about the WEAR SENSOR - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 03-15-2008, 09:26 AM Thread Starter
Date registered: Sep 2006
Vehicle: Proton Saga BLM
Send a message via MSN to jrkong Send a message via Skype™ to jrkong
Unhappy It's about the WEAR SENSOR
Hi all,once again to ask for help from all of you.A C-Class Kompressor WDC2030452R013707 came to our workshop.The driver said,"Brake Lining Wear Sensor" pops up,once turn off the engine and start again,it won't pops up again.sometime will come up even the brake paddle is free.May i know what is the problem?
I checked the front wear sensors and the brake lining,both side are still in good condition.There are no any wear sensor at the rear side.
jrkong is offline
post #2 of 2 (permalink) Old 03-15-2008, 03:34 PM
Date registered: Jan 2007
Vehicle: 2002 honda civic (sold), 2009 Mercedes ML350
Quoted: 4 Post(s)
pull the wheels off and physically check the wear sensors. if need be install new ones for testing. if it still happens then you may have a wire shorting or a bad front sam.
Streetglower is offline
    Brake pad wear sensor? bossman123 W210 E-Class 5 11-30-2007 04:42 PM
    Brake Wear Sensor jallbutt W124 E,CE,D,TD Class 3 08-23-2004 04:06 PM
    Brake wear sensor M Arrow W163 M-Class 1 02-07-2004 11:06 AM
    Brake wear sensor - does it work? sdgrossman1 W124 E,CE,D,TD Class 6 10-13-2003 12:17 PM
    E Class Brake Wear Sensor light is ON Darkmann W210 E-Class 3 09-07-2003 01:25 PM
