C1120 N64 ESP yaw rate sensor.zero point offset error of component - Mercedes-Benz Forum
post #1 of 12 (permalink) Old 03-11-2008, 07:06 AM Thread Starter
Date registered: Sep 2006
Vehicle: Proton Saga BLM
Send a message via MSN to jrkong Send a message via Skype™ to jrkong
Hi all,ESP pops up in the instrument cluster.i ran short test by star diagnostic.below was the result:
C1120 N64 ESP yaw rate sensor.zero point offset error of component N64.
I tried to press the ESP button,but the symbol in the instrument cluster doesn't go out. Can you give me any tips to solve this problem.
jrkong is offline
post #2 of 12 (permalink) Old 03-11-2008, 07:24 AM
eric242340's Avatar
Quoted: 312 Post(s)
You can try to reset this one but it needs star diagnostics to preset the test programme. Once the programme is put in test mode, then you must road test the car and perform the re set, ie drive the car for 10 km in a straight line and then swerve left and right for 100M, then do a u turn. The last one I did took five tests before it worked.
The yaw rate sensor is very sensitve and sometimes the reset works but most times the sensor has to be changed and if you dont have star D then you will have to take it to the stealers or a specialist.
ERIC.
eric242340 is offline
post #3 of 12 (permalink) Old 03-11-2008, 08:17 AM Thread Starter
Unhappy
thanks for your reply eric.i retrieved the TDC by DAS.i performed road test for few times.but still the same fault.now even worse..ROAD TEST:ACTIVE shown on the DAS.what is the problem?DAS requested me to perform road test again. and BAS,ABS,EPS NOT AVAILABLE DIAGNOSE. /RIG TEST.shown on the instrument cluster now.what is going on eric..please..
jrkong is offline
post #4 of 12 (permalink) Old 03-11-2008, 08:20 AM Thread Starter
may i know what is the actual value for the yaw rate sensor when the car is in standstil condition?it was 19.1.
jrkong is offline
post #5 of 12 (permalink) Old 03-11-2008, 08:34 AM
eric242340's Avatar
Quoted: 312 Post(s)
Did you follow the proceedure as per das instructions, ie switch ESP off before perfoming the test? This is a complex test and may need to be performed several times before it works. You must swerve the car left and right (quite violently) during the test. And road test Active means you have not completed the test. ESP BAS ABS will not be available during the test cycle its normal.
ERIC.
post #6 of 12 (permalink) Old 03-11-2008, 05:39 PM Thread Starter
actually i accidentally done the road test.but yesterday i tried to run road test again,it came out again.i follow the instructions given.maybe i haven't completely done the road test.may i know what is the actual value of the yaw rate sensor when the car is in standstil condition?
jrkong is offline
post #7 of 12 (permalink) Old 03-11-2008, 10:26 PM
eric242340's Avatar
Quoted: 312 Post(s)
Ive been thinking about your problem and a few points that came to mind but:
1. Has the sensor been changed?
2. Was the battery disconnected?
3. Has the steering angle sensor been reset?
4. What is the vehicle model and year clk/slk?
ERIC.
post #8 of 12 (permalink) Old 03-12-2008, 07:22 AM Thread Starter
1.I haven't change the sensor yet.i will change it tomorrow.
2.i disconnected the battery negative terminal for few times,it was still the same when i connected the terminal.
3.yes,i done the harmonization of the steering angle.
4WDC2030452R013707
jrkong is offline
post #9 of 12 (permalink) Old 03-12-2008, 07:33 AM
eric242340's Avatar
Quoted: 312 Post(s)
4WDC2030452R013707
In this case change the sensor first and then look again, you are moving in the right direction im sure.
ERIC.
post #10 of 12 (permalink) Old 03-12-2008, 07:40 AM Thread Starter
i will let you know the result tomorrow.hey man,you from shenzhen?chinese?
jrkong is offline
Yaw Rate Sensor and ESP/BAS light Dting22 W163 M-Class 150 04-05-2016 11:28 PM
C1120 N64 ESP yaw rate sensor.zero point offset error of component jrkong W203 C32 AMG, C55 AMG 2 03-11-2008 05:42 PM
99 ML430 YAW Rate Sensor mlCharlie W163 M-Class 1 09-22-2006 01:49 PM
Is this Considered Dangerous-C1120 ESP Yaw Sensor Code? TankNoir W140 S-Class 1 05-27-2006 07:55 AM
Yaw rate sensor - 1998 C280 aes1128 W202 C-Class 1 07-05-2004 10:44 AM
